Side Trim Mounting Studs
I have a '77 short wide strip model. I want to put the side trim on, but there are no mounting studs. How can I over come this?
Getting Old; Going Broke
Re: Side Trim Mounting Studs
Pretty sure the new aftermarket kits come with tabs that are held on with doubleback tape and not the tabs held on with rivets.
Why is every used 350 sbc out of a corvette? There's only two things that excite a man, expensive toys and real expensive toys. VEGETARIAN: That's an old Indian word meaning "I don't hunt so good." When the going gets tough, switch to power tools. |
Some of the moldings will have studs and some will use studs and double side tape.
The fender mouldings all use studs with speed nuts. The doors will have one stud and the rest will be tape. the bedsides use tape and i think a screw on each end. Randy was right if you buy new mouldings they will come hardware.
___________________ 78 ccsb dually 5.3 4l60e http://67-72chevytrucks.com/vboard/s...d.php?t=491551 |
