Old 06-21-2012, 09:08 PM   #1
Gordonr1973
Home Built '87
Gordonr1973's Avatar
LQ9 Misfire Code??
HI,
just going through the formal camshaft break-in and I'm getting a code on my code reader that says "cylinder 6 misfire detected".
Now, the engine sounds okay, but I haven't taken the truck in for a final PCM tune yet....
I'm wondering should I continue the break-in process and see what happens, or should I stop completely???
I have the truck booked in for the exhaust to get done tomorrow .... wondering if I would be okay to drive it there to finish that then worry about the misfire?
I'm unclear how much concern I should be paying to this code in an LS engine at this pioint before the final tune??
Thanks for your suggestions.
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 06-21-2012, 09:17 PM   #2
Gordonr1973
Home Built '87
Re: LQ9 Misfire Code??
And which one is cylinder six by the way...I'm searching the net for a diagram as well
Gordon
Old 06-21-2012, 09:47 PM   #3
clinebarger
Originally Posted by Gordonr1973 View Post
HI,
3rd cylinder back on the passenger side is number 6, Roller cams do not require break-in.
Check for spark & injector pulse on #6, Check for a cracked spark plug. Open headers/big cam can cause a P0300 multible misfire code. But not certain cylinder misfires unless its actually misfiring on that cylinder.
P0306 is the misfire code for cylinder #6.
clinebarger is offline   Reply With Quote
Old 06-21-2012, 10:51 PM   #4
Gordonr1973
Home Built '87
Thanks Cline!! I will definitely keep my eye on that. Tat's a good tip on the cylinder # verses the code number, I didn't know that either!
I wasn't sure about the break-in either on the roller cam but I thought what the heck, may as well run it for a while with open headers & annoy my crazy neighbor and see if he calls by-law on me tonight. lol
I checked my plug wires and #6 was loose. Duh!! Pushed it back on and no more codes.
Someday I will learn!
Gordon
