Old 06-21-2012, 11:38 PM   #1
JNJchev77
Registered Cruiser
JNJchev77's Avatar
Sending unit help, factory gauges
Hey guys, have a few simple questions/requests.
I'm swapping a 5.3 into my 77 and want to use factory gauges.
- I know I need and adapter for the oil s.u., preferably auto meter part 2268. But what sending unit are you guys using? Any pics of this set up? I'm setting this up at the rear of the block.
- And for the temp sending, what are you guys using? I know the location of this s.u., but can I use the original sending unit with an adapter?
As always, thanks in advance for the help!!
Justin
77' Chevy SB
Dropmembered Front and Rear
5.3/4l60e combo
JNJchev77 is offline   Reply With Quote
Old 06-22-2012, 12:12 PM   #2
JNJchev77
Registered Cruiser
JNJchev77's Avatar
Re: Sending unit help, factory gauges
Nobody?
My factory oil pressure gauge has a hard line female input (mechanical), no electrical. Do I need any electrical for warning lights? Or does the the pressure line screw directly in to the auto meter adapter?
Can I use this gauge, or do I need to switch to an elec gauge?
77' Chevy SB
5.3/4l60e combo
Old 06-22-2012, 04:00 PM   #3
6.0 1955
I used the factory gauges in my 69 c10. For oil pressure just break off the top of the 5.3's oil sending unit. Once the black plastic filler of the sending is gone you will see a small hole in the aluminum body. Now drill out the hole and tap it to you desired size. For the water temp gauge we used the 5.3's front passenger side head hole. Removed the original 5.3 sending unit then drilled and tapped the head to accept the original 69 c10 sending unit. Gauges work great and dash looks original. I'm running a th350 trans so my speedometer is still cable driven. If you don't want to drill and tap contact street and performance as the sell adapters that fit these locations. But when on a tight budget my method works well.
6.0 1955 is offline   Reply With Quote
Old 06-22-2012, 06:30 PM   #4
ls1nova71
ls1nova71's Avatar
I've been doing it the way 6.0 1955 said, for years, works great! Why spend money on a fitting, when you can make it for little bit of nothing? Oh, probably because I'm cheap.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 06-25-2012, 01:53 PM   #5
pwtr02ss
I used the street and performance adapters. A bit pricey but it works
pwtr02ss is offline   Reply With Quote
Old 09-01-2012, 02:50 AM   #6
lytemup454
lytemup454's Avatar
I planned on doing this mod, but what about the wiring/ plug and the computer? will it not run if it isn't getting a signal from the sensor?
lytemup454 is offline   Reply With Quote
Old 09-01-2012, 03:48 AM   #7
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
it should run fine...iirc all low o.p. did was trigger an idiot light, not actually prevent anything mechanically.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 09-10-2012, 12:39 PM   #8
OneOffStroker
The ECU sensor on the driver's side head should stay connected to the ECU. There is a plug on the rear of the passenger head that you can remove and install a sensor for temperature with the right metric-NPT adapter. (I used EQUUS adapters)
1972 C10 "Shop Truck" Build - EFI, 5-speed, Posi, and Patina http://67-72chevytrucks.com/vboard/s...d.php?t=834292
1957 Chevy pickup - Twin Turbo 5.3/NV3500, Jag IFS & IRS, AirRide http://67-72chevytrucks.com/vboard/s...d.php?t=606987
Check me out on YouTube - "Tiny Garage Fabrication" http://www.youtube.com/oneoffstroker
OneOffStroker is offline   Reply With Quote
Old 09-14-2012, 09:59 AM   #9
mooseknuckles
mooseknuckles's Avatar
im running new autometer electric guages and the autometer metric adapters...I belive #2268 and #2277?
mooseknuckles is offline   Reply With Quote
Old 09-14-2012, 10:54 AM   #10
JNJchev77
Registered Cruiser
JNJchev77's Avatar
I decided to use aftermarket Auto Meter gauges! No more cluster issues, mis-readings, etc.
77' Chevy SB
5.3/4l60e combo
Old 09-14-2012, 11:00 AM   #11
mooseknuckles
yeah....just seemed easier to do..
Old 09-15-2012, 01:27 PM   #12
brad_man_72
the boat guy
brad_man_72's Avatar
Mech oil pressuer gage - drill and tap the small plate above the oil filter, use factory line.
Engine temp gage - put aftermarket style metric sending unit in pass side head where there's a plug now.
Tach - whoever does your tune have them modify the tach signal for the factory tach.
Mech speedo - plenty of options, most cost about $200. Or you can modify eletronic speedo to look like factory gage by using factory face and needle.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
