Old 06-22-2012, 12:49 AM   #1
mike14_07
mike14_07's Avatar
Bad fuel gauge?
Checked out my fuel gauge today, it shows full w key on all the time. I started with the sending unit, I checked the ground to the cab, good, checked voltage i get 5.50 volts, i go to the fuse panel, i got 5.5 volts there too. i go up the gauge, unplug the connector from the gauge i have 12 volts on the hot wire(pink). so i think the wire is bad in between the gauge and the fuse block(tan). i check it at the plug on the column, 5.5v. so i go back to the gauge, check it at the back of the connector, 5.5v. i pull the plug looks good. so does that mean the gauge is bad?
mike14_07 is offline   Reply With Quote
Old 06-22-2012, 08:35 AM   #2
1963c-10
1963c-10's Avatar
Re: Bad fuel gauge?
Did you move the arm on the sending unit to see if the guage moved while it was out?
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
