06-22-2012, 01:26 PM | #1 |
What color is the green in the instrument panel?
Anyone know what color or what rattle can to buy for the greenish color on the inside of the instrumetn panel on 72? Thanks!
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles 72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2) 2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end 2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED) 2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one) Hook em Horns!!! |
06-22-2012, 02:12 PM | #2 |
Re: What color is the green in the instrument panel?
though not a perfect match - it's darn close. If doing a whole cluster, you'd never know the difference - but if only parts of it, you could see a slight tint difference between the two. It works well though.
06-22-2012, 02:20 PM | #3 |
That IS close! Repainting the whole thing so that would be good!
06-22-2012, 03:16 PM | #4 |
Moderator
Catalina Mist from Krylon is a dead on match.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
06-22-2012, 04:37 PM | #5 |
Noted! Wish I'd found that first!! I didn't see it at wally world, but if they're both krylon, it's gotta be laying around pretty common-like. Is the cataline mist satin?
06-22-2012, 04:39 PM | #6 |
Moderator
Catalina mist is satin also. There are 2 different greens used on the tins. The catalina mist i have found to match the inside of the outer tin (the tin the gauges mount to). The inner tin is slightly darker. Is Jade the one you used for the inner tin? It looks like it matches the darker green.
06-22-2012, 04:41 PM | #7 |
Yes, that's what I used. that tin in the pic is actually from a Pontiac vac gauge that I ended up not needing for the vac install, more of a "test firing" of the green. Good point on the 2 shades.
