Utilizing the center dash speaker location in an 87 R10??
I am thinking of using the center opening in my dash to hold 2 4" speakers that i have left over. I did a quick search and found some similar ideas. Does anybody know if there is an adapter only that you can buy that will work for 2 4" speakers in this location? Thanks!
Slots go on anything!
Re: Utilizing the center dash speaker location in an 87 R10??
I used some plumbers strap and made it work in my '87. Put the tweeters in the outboard spots the same way.
1974 Jimmy- 5.3/4L80e/NP241 |
Didnt even think of that. I currently have 2 6x9's going in the corners and 3.5" in the dash corners. I have the 4" pair laying around from an old vehicle so i figured that i might as well put them in.
I did just that since my 76 only has the center location. My truck still had a 4x10 there so I took it out and traced it onto sheetmetal, cut it out, and then cut two 4" holes in it. I'm not aware of a premade bracket but it really wasn't hard to make at all. You could probably even make it out of mdf and mount it from underneath.
In the Forgotten far North.
![]() Join Date: Jul 2007
Got mine from LMC. Two 4" speakers on one bracket mounted in the center and am utilizing it as a center channel for my 5.1 channel surround sound kenwood system.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
