Old 06-22-2012, 05:59 PM   #1
duckdude
tach help
is there a way to check if the tach for a dash is good without hooking it up to the truck?
duckdude is offline   Reply With Quote
Old 06-22-2012, 06:13 PM   #2
VA72C10
VA72C10
VA72C10's Avatar
Re: tach help
ground it, and hook up the wiring to the distributor and a 12v power source...
oops...I was thinking without installing in the dash...not without a truck at all... the only way I know is visual inspection (no loose wires/solders inside under the cardboard tube (take the face off to get the tube off))
The needle should be freely moving by hand...
Most of the time a factory tach will be fine...but the only way to be 100% sure is to hook it up.
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 06-22-2012, 09:20 PM   #3
duckdude
Re: tach help
thanks VA72C10 for the help. found a guy that has 3 of the tach dashes cheap and wanted to check them before i pop on them.
