Old 06-22-2012, 10:28 PM   #1
ClassicGuy
70 c10 driveshaft length?
I have a 1970 C10 shortbed and I am installing a 383 stroker with a 700r4 tranny. What size driveshaft should I use? And can I use one from any other vehicle that will fit? Thanks for the help.
ClassicGuy is offline   Reply With Quote
Old 06-22-2012, 10:51 PM   #2
GMC Canuck
Re: 70 c10 driveshaft length?
I have the same engine and transmission in my '68. I had a one piece (I believe it was 3.5" chromoly) made. They told me it was the upper limit for length of a one piece shaft. But at the time a custom built two piece was not in the budget. It has worked fine. I highly recommend getting a proper shaft built, the potential for vibration is huge with a one piece especially if you're running a high ratio rear end. The measurement is easy once you have the engine and transmission sitting in place.
I twisted off two originals before I made the switch. Bearing stuff is cool, the first one made a cool trophy. Breaking the same part twice, not so cool.
If you do go to a once piece. Cut the hanger bearing mount off the crossmember. Otherwise the 'tink' noise you hear at the first set of train tracks will make your skin crawl.
GMC Canuck is offline   Reply With Quote
Old 06-22-2012, 11:02 PM   #3
ClassicGuy
Thanks. Who did you go through to get it made?
Old 06-22-2012, 11:10 PM   #4
GMC Canuck
Place in windsor called Bears performance. Almost every city will have a driveline shop somewhere. Most will service mainly big trucks and pto stuff but will also do work for custom and race guys as well. Most won't have a flashy web page like bears so you may have to do some digging.
Old 06-23-2012, 12:01 AM   #5
ClassicGuy
Is that Windsor California?
Old 06-23-2012, 07:44 AM   #6
GMC Canuck
windsor, Ontario
