06-23-2012, 02:42 AM | #1 |
tilt columns
I got an ididit column with a floor shift and was wondering if the is anyway to use a 40's or 50's steering wheel on it
Posted via Mobile Device |
06-23-2012, 10:53 AM | #2 |
Re: tilt columns
Ididit makes some adapters readily available for their columns and older steering wheels. I think they might offer custom jobs too. Best way to get an accurate answer would be to call them direct.
06-24-2012, 12:07 AM | #3 |
Re: tilt columns
Look at my build thread, in the middle of adapting a 48 big truck wheel to Cady tilt telescope column.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
06-24-2012, 12:09 AM | #4 |
Re: tilt columns
Ididit with a '56 truck wheel on it...fit with no problem..
06-24-2012, 01:58 AM | #5 |
Re: tilt columns
06-24-2012, 02:06 AM | #6 |
Re: tilt columns
06-24-2012, 10:08 AM | #7 |
Re: tilt columns
Looks nice parkwood!
06-24-2012, 10:21 AM | #8 |
Re: tilt columns
You would have to check with Ididit but I'm pretty sure that they use the same spline on the steering shaft that GM has used since the early 50's.
The fun part would be getting the turn signal canceling cam to work and getting the horn to work. That may not be so hard though as they have an adapter for 55/68 wheels http://www.ididitinc.com/accessory_p...l_adaptors.htm Last edited by mr48chev; 06-24-2012 at 10:28 AM. |
06-24-2012, 11:38 PM | #9 |
Re: tilt columns
Parkwood, are you using a tilt column? Did you use Ididit's horn kit for the 55-68 stock steering wheel? Anything else required?
06-25-2012, 11:30 PM | #10 |
Re: tilt columns
Yes it was a Ididit tilt column and to use the steering wheel off a '57 truck all i had to do was spot weld a little tab on the horn ring to be able to hook up the wire from the column.
06-26-2012, 09:57 AM | #11 |
Re: tilt columns
Mine is an Idiot. though I havent made the brass tag yet.
http://67-72chevytrucks.com/vboard/s...d.php?t=474288 Parkwood that is good to know thanks |
