Old 06-23-2012, 09:02 AM   #1
67 chevy heaven
HELP!!! upper/lower control arm info needed
Hey all,
Once again I show my utmost ignorance with a 67-72 truck rebuild!!!
I took my whole entire front end apart to por15 the frame. I somehow lost the shims that go on the upper control arm shafts that align the camber.(i believe) I also cant remember where the spacers go or how to properly assemble the lower/upper shaft assys. can someone please come to my rescue!!! This is my first truck, or any auto rebuild for that matter and I have been schooled in the "school of hard knocks" and it sucks. Can some of you guys that are knowledgeable about these things take some time out of your busy schedules to get me back on track. REAL elementary descriptions and pics would be soooooo helpful.
Your help and info. is greatly, greatly, appreciated!!
SHAHOU8@aol.com
67 chevy heaven is offline   Reply With Quote
Old 06-23-2012, 11:22 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: HELP!!! upper/lower control arm info needed
67 chevy heaven- Slow down, take a deep breath and relax. Your not the first one that has taken something apart and can't remember how to put it back together.
what I recommend is taking pics before you disassemble, and bag and tag your parts.
Let me dig through my files and see what I can find for suspension pics.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 06-23-2012, 12:52 PM   #3
FLEET72
FLEET72's Avatar
here is a shot of the upper
Oscar
'72 Shortbed Fleetside
'95 Jimmy 4X4
'69 GMC Custom Camper
FLEET72 is offline   Reply With Quote
Old 06-23-2012, 01:24 PM   #4
67 chevy heaven
N2TRUX you are right. thanks for the pep talk I really needed it. I knew to place parts in labeled bags but I just got ahead of myself getting everything ready to be coated. Your help and pics will be greatly appreciated.
Fleet 72 thanks for the pic. Can you tell me what is behind the shims?
I have the concave spacers but I dont have everything that is labeled in the LMC catalog.
I would like clear pics and a list of what part/piece goes on at the place.
Thanks again guys. Your time and help is really appreciated.
Can someone tell me if I will be able determine what size shim/shims what will be needed to have the correct alignment of the front end?
Old 06-23-2012, 02:21 PM   #5
FLEET72
FLEET72's Avatar
Does this help?
From LMC's page:
13 is listed as a flat washer and 14, a nut.
On my truck, which as far as I know is still mostly factory, looks like a self-aligning washer set.
Oscar
'95 Jimmy 4X4
Old 06-23-2012, 06:24 PM   #6
67 chevy heaven
FLEET72, I love the help. In the diagram, the #10 part is something that I do not have. Is this a standard piece? Or is this only on 3/4 ton trucks only?
Old 06-23-2012, 07:22 PM   #7
67 chevy heaven
also, what about the shims that are shaped like a "Y" since I no longer have them will I be able to find someone (front end shop may be) that can figure out which ones that I will need
Old 06-28-2012, 07:21 PM   #8
67 chevy heaven
can anyone else get me a few pics of their control arms that are a little cleaner?
I am so thankful for all help,
Old 06-28-2012, 07:26 PM   #9
Pro Performance
Pro Performance's Avatar
#9 is your alignment shims. You should be able to get those at your local auto parts store, since it is a common part. Sounds like you need to have it aligned as well, after dis-assembling the front suspension. Wherever you take it to be aligned, should have those as well. They get removed or more installed to adjust the camber of your wheel.
I have the #10 part on my truck, but not sure if that is through all the years. Mine is an 84. Maybe the 67-72 trucks don't have them.
Pro Performance is offline   Reply With Quote
Old 06-28-2012, 08:12 PM   #10
asolde
asolde's Avatar
I put mine back together the way I took it apart. That don't mean it's right. I did not have item 10 but I did have items 13 & 14 and 9 the shims. When you put the lower shaft back together pay attenion to the recessed hole in the shaft and the protrution on your fwd clamp they fit together. Have you got a shop manual? That would help you too. My truck is a 1972 1/2 ton.
asolde is offline   Reply With Quote
Old 06-28-2012, 08:16 PM   #11
Fattback
Fattback's Avatar
Some from my 72. hope it helps
Rob
Fattback is offline   Reply With Quote
Old 06-28-2012, 08:41 PM   #12
FLEET72
FLEET72's Avatar
Just for you!
The convex washer I could not budge, the concave washer I am holding here.
The shim stack on the passenger side of my truck. I don't think it matters WHAT is filling that dimension as long as it is the correct thickness to achieve proper alignment.
If you get it pretty close, you can drive it to an alignment shop and have them do a proper job so you don't wear out your tires.
Oscar
'95 Jimmy 4X4
Old 06-29-2012, 01:35 PM   #13
FLEET72
FLEET72's Avatar
The lower shaft:
Up close:
Oscar
'95 Jimmy 4X4
Old 10-07-2012, 11:22 AM   #14
OldYeller72
Anybody have an idea of what size the nut is on the upper & lower control arm shaft?
I am about to remove the shafts on my 72. The lower shafts have no play or any signs of wear but I am doing a complete suspension resto and want to know it is all new. I have never done the lower CA before, so if anybody has any information to offer I would be indebted. Really need to know the sizes of the nuts so I can go rent the tool, no sense in buying them, because I will have no need for them after this.
Thanks in Advance
OldYeller72 is offline   Reply With Quote
Old 04-17-2013, 12:56 AM   #15
First c10
First c10's Avatar
I know this is an old thread but the # 10 looks like the washer that it flat on one side and curved on the other. The curved side goes towards the shaft if your shaft uses them. The 73-87 shafts I am installing use this shaft and washer. I am going to us the 2 piece style first than shims and then the #10 washer then the shaft. Hope it works. Oh also my shaft nuts were 3/4".
Good luck
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 07-25-2013, 11:24 PM   #16
3rdGen.c10
3rdGen.c10's Avatar
okay I have a question... when I install my tubular control arms do I reuse the dished spacers? the female and male spacers from above? I have a 67 c10 with cpp tubular uppers and 85 factory stamped lowers. any help appreciated.
1967 c10 stepside 6.0L 4L80E
3rdGen.c10 is offline   Reply With Quote
Old 07-26-2013, 08:31 AM   #17
SCOTI
SCOTI's Avatar
The arms shafts should seat squarely & flush. If you need the curved spacers to keep things seated correctly, use them. If the arms seat correctly w/o them, they're not needed.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-26-2013, 11:13 PM   #18
spatz
to old yeller72, upper control arm uses 1 3/8 and lower uses 1 5/8. I bought 3/4 inch drive sockets with a 3/4 to 1/2 adapter at autozone, sockets were about 9 bucks apiece.
spatz is offline   Reply With Quote
Old 07-27-2013, 03:51 PM   #19
3rdGen.c10
3rdGen.c10's Avatar
Thumbs down Re: HELP!!! upper/lower control arm info needed
Okay so I don't have to use the one that presses on? I figured it secured the stud in place by sandwiches the frame.
Old 07-28-2013, 08:06 PM   #20
Ralph (1970 GMC)
This is great - thank you all so much for the parts info and close up photos as I am about to do the same thing with a disc brake conversion and replacing my control arms & front cross member due to rust.
Question : When bolting back on the (‘new’) front cross member : do you use a washer on the bolt head side (it appears GM didn't originally) and on the other/nut side do you use a 'washer/ then lock washer/then regular nut' or do you use a 'washer and lock nut' ? What do you all do/suggest please ?
Ralph (1970 GMC) is offline   Reply With Quote
Old 07-30-2013, 09:17 PM   #21
spatz
Ralph (1970 gmc) I just put the crossmember in my truck and mine was flat washer, then lock washer, then nut. the original was that way and was a little loose And i used lock nuts and tightened to specs.
Old 07-31-2013, 03:32 PM   #22
Ralph (1970 GMC)
Spatz : thank you, that sounds good - I'm curious about "tightened to specs" - could you tell me more about the specs please.
Ralph
Old 07-31-2013, 10:59 PM   #23
spatz
specs should be for side frame rail 55 - 75 ft lbs and for lower frame rail three bolts are 80 to 120 ft lbs straight from the assembly manual.
Old 08-01-2013, 12:51 PM   #24
Ralph (1970 GMC)
spatz : Thanks again - much appreciated !
Ralph
Old 07-21-2020, 11:50 AM   #25
Big Kev-O
Big Kev-O's Avatar
Bringing back an old thread because I have some questions regarding the spherical washers seen in the pictures. Do they serve a purpose or can i use regular washers?
The 71-72 cross shafts are flat, unlike my original 68 shaft which curved and used a washer that was flat on one side and curved on the other. So can I just use some regular washers and let the alignment guy add shims as needed?
Thank you!
Made in America by Americans
Big Kev-O is offline   Reply With Quote
