2 problems i need help with
250 inline 6 1bbl carb when i get going on the interstate at like 65-70 it feels like the motor cuts in and out about every 3 to 4 mins, also i bought a new alternator (160 amp racing alternator) and my volts are in the red at nightime
77 c10 (went from a inline 6 to 350) (converted to 3 speed in the floor) 350: mild cam, holley 600cfm 4bbl, summit stage 1 intake, accel billet distributer, flowtech headers, 2 1/4" exhaust with glasspacks, powermaster 160a alternator. |
Re: 2 problems i need help with
anyone?
I thought you were going to get rid of that motor and put a 8 in it?
1985 Chevrolet K10 Custom Deluxe---SOLD 1997 Ram 2500 5.9 Cummins 1985 Chevrolet Camaro Z28 1987 Chevrolet K10 Silverado "The Beast" build 1987 Silverado http://67-72chevytrucks.com/vboard/s...=1#post6150257 |
is The filter clean? getting enough fuel? Redzone as in 8 volts or 18?
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ] ![]() 1999 k3500 crew cab dually 6.5tdi/4l80e |
also at the rpm's it would run at interstate speed could your vacuum advance not be working? have you checked and cleaned the dizzy cap and rotor? check you plug wires. As these trucks don't have obd it wouldn't throw a light if it was skipping or misfiring.
bad connections can cause the alt to overcharge. had a bad connection on one of my batteries that was making it do that on mine. it had a voltage drop and ramped it up.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
i fixed the volts problem but not the other one. could it also be bad gas because it didnt do this until i went to a new gas station in town with "cheaper" gas
Bad gas might be plausible, our Camaro wouldn't run very great and even died with BP gas and we had to flush it and use another brand of gas.
yeah and i decided to keep the 6 in there till it blows haha. and i know this is kind of off topic but someone told me wheel spacers are hard on your wheel bearings is this true? because im thinking about getting 2in spacers
well adds a point of failure. the leverage could translate onto the bearings.
well the motor cutting in and out problem has gotten horribly worse its like it floods itself out when going up hills on the instersate. ive put different gas in it over and over ive tried 93 it dont help.
This may sound stupid but have you checked the plugs or replaced them?
#13 |
i though of the same thing but they was just put in about 3k miles ago, oh and its been knocking really bad here lately, changed the oil and everything no help
#14 |
I don't know much about the way straight 6's are built or really how to diagnose them but generally knocking in a engine is not good at all. You may be switching to a V8 sooner than you think.
#15 |
ive already decided to park the truck until i get a motor and then the 6 gets one last ride to my buddies shop so we can take it out
#16 |
Haha, have you decided what your going to replace it with yet?
#17 |
hopefully a 327, if i cant find one then the good ole 350
#18 |
327 that would be cool, are you gonna build it?
#19 |
i dont know. if i do it will be very little im basically broke this truck has took all my money! haha
#20 |
Cool well good luck either way you go.
#21 |
yeah id like to have it decent on gas also i remember when i had this truck and didnt have my license i didnt think gas would be that bad but then when i start driving it all the time its 20$ a whack
#22 |
Yeah we have owned my truck since before I could drive, but at least gas prices are starting to go down.
#23 |
how much are they up there?
#24 |
Gas as of right now is $3.21 a gallon in northern Indiana.
#25 |
oh its 2.95 and it keeps going down here in northren nc
