06-23-2012, 12:29 PM | #1 |
Starter help
So I'm on my 5 th? Starter in 4 months! I got it from orieleys ,luckily I have the lifetime warranty.but I'm fed up with having to change it soo much! What starter are you guys using? I have a 350/350 with staggered mounted starter,i searched and saw many complaints about orieleys starters ,so I'm hoping the one I get today is my last,because I'm gonna order one based on your suggestions. Thanks for any help
Posted via Mobile Device |
06-23-2012, 03:06 PM | #2 |
Re: Starter help
Couple thoughts!!
Are you using the factory knurled shank bolts to bolt it on with and a brace to help hold up the backend? |
06-23-2012, 03:09 PM | #3 |
Re: Starter help
Yes on the bolts,no brace. Never had a brace
06-23-2012, 06:16 PM | #4 |
Re: Starter help
Thanks!
So what exactly is it doing? Are you replacing the complete starter and solenoid or just the starter. I've seen a couple bad starters in a row but not 5 of them. |
06-24-2012, 01:51 PM | #5 |
Re: Starter help
could be low voltage or bad engine ground either one heats up a starter really fast and they wont last long make sure you have a large gauge positive and ground cable i always use the 2/0 cables the little 4/0 cables just cant handle the higher amperage's of these older starter designs
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice |
06-24-2012, 02:32 PM | #6 |
Re: Starter help
Good thinking ,I'll check the ground strap to the engine! Haven't thought of that yet.i noticed I have a slight rear main seal leak and it drips to the starter. Not much oil, but could that be a cause of the starters failing too? The problem I've been having is the starters nagged perfectly for a certain amount of time then they start to grind on the flywheel. New flywheel 2 starters ago because I wanted to be sure that wasn't the problem
06-24-2012, 06:18 PM | #7 |
Re: Starter help
When you replaced starters and flexplate did you gauge the clearance between them...?
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
