Old 06-23-2012, 04:06 PM   #1
86c20
86c20's Avatar
ac condenser??
how are are they to replace? the one in my 85 k30 has a leak so it needs to go. is there anything i should know?
thanks, mike
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph
1985 k30 "the ice cream truck from hell" no rust az truck
197-8??? c30 "ramp truck" 454
1978 monte carlo 350 350th with 2.73 gears. no rust. sc car
86c20 is offline   Reply With Quote
Old 06-23-2012, 05:36 PM   #2
chengny
chengny's Avatar
Re: ac condenser??
Not too bad to R&R. GMC shop manual procedure:
REMOVE OR DISCONNECT
1.Battery ground cable.
2.Discharge the system.
3.Grille assembly.
4.Radiator grille center support.
5.Left grille support to upper fender support (2) screws.
6.Condenser inlet and outlet lines, and the outlet tube at the right end of the condenser.
CAUTION: Cap or plug all open connections.
7.Condenser to radiator support screws.
8.Bend the left grille support outboard to gain clearance for condenser removal.
9.Condenser assembly by pulling it forward and then lowering it from the vehicle.
INSTALL OR CONNECT
1.New condenser.
CAUTION: Add 30 ml (1 ounce) of clean refrigeration oil to a new condenser.
2.Left grille Support.
3.Radiator support screws.
4.Condenser inlet and outlet lines.
CAUTION: Use new seals (O-rings) coated with clear refrigeration when connecting refrigerant lines.
5.Left grille support to the upper fender support screws.
6.Radiator center support.
7.Grille assembly.
8.Battery ground cable.
If you don't feel like tearing the grill and radiator support apart, just drain and pull the radiator (push the shroud back) and remove the condenser from inside the engine compartment.
chengny is offline   Reply With Quote
Old 06-23-2012, 09:26 PM   #3
DetroitIron
DetroitIron's Avatar
Re: ac condenser??
I have a plow rack which makes taking the grill apart a nightmare...the last sentence from chengny is very spot on about taking the radiator out is the way I just did mine. for what its worth
_______________________________________________
1985 Chevy Scottsdale K20 350 with 700R4 running 3.42 gearing aka "The Honey Badger"
1993 Silverado C3500 Ext. Cab Dually 6.5 turbo diesel
DetroitIron is offline   Reply With Quote
Old 06-23-2012, 09:54 PM   #4
crazeetxn
crazeetxn's Avatar
Re: ac condenser??
+1 on chengny. Had to take my grill, condersor, and radiator off to get to the harmonic balancer one time. Piece of cake.
1st - '68 long bed
2nd - '81 SWB
Now - '86 SWB, Edelbrock 1406/stock 350/700r4
crazeetxn is offline   Reply With Quote
Old 06-23-2012, 10:21 PM   #5
88Jimmy4x4
88Jimmy4x4's Avatar
Re: ac condenser??
thanks, mike
its easy, 2 bolts top and 2 bolts bottom once grille is removed and grille mounting brackets......did mine 2 weeks ago. You will need new o-rings for the lines....get the green ones
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 06-24-2012, 03:25 PM   #6
86c20
86c20's Avatar
Re: ac condenser??
sorry guys i am not up and the ac names. i need the one on the fire wall. i thought that was the condenser. must be the evaporator??? and was told a new dryer too can i ask why? thanks and sorry for my mistake. later, mike
Old 06-24-2012, 05:12 PM   #7
hatzie
Moderator
hatzie's Avatar
Re: ac condenser??
The Evaporator is fairly easy to replace. Install a Variable Orifice Valve at the same time.
You need a new drier any time you crack open an AC system or have a leak because moist air quickly saturates the desiccant pak. You should wait to remove the seals and install the new drier just before you vac the system down.
Once the system is sealed crack the high side port and blow a dry inert gas like Nitrogen, CO2, or Argon through the sealed system from the low side port. Blow it through for a couple minutes to sweep out most of the moist ambient air. This should keep the oil and drier from absorbing too much moisture. It'll make your vacuum pump happier too.
Updating to R134.
You will want to make sure that there is a High Pressure cutout switch installed and that the High and Low Pressure Cutouts are set up for R134 pressures.
You can get away with cutting off the collars and replacing the flexible portion of the lines with new barrier hose and new crimp collars.
Every O ring in the system will need to be updated to R134 spec.
You'll also want to flush the R12 oil out of the lines and condenser (unless you upgrade the condenser).
Installing a high efficiency parallel flow condenser will keep the vent temps down when idling.
Drain and refill the compressor with a full charge of Ester oil. Ester won't have a conniption over the dregs of R12 mineral oil left in the system and it's less hygroscopic than PAG oil. Don't burn the old mineral oil. It probably still has some R12 trapped. You do not want to breathe Phosgene gas.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
