Old 06-24-2012, 11:42 AM   #1
tc4x4
tc4x4's Avatar
Ford 9 inch axle questions
Would this be a good axle to put into the rear end, to get rid of the one ton axle? Its got 5 lug nuts, I'm thinking of getting rid of the one ton front and rear so my options open up with the build.
http://nmi.craigslist.org/pts/3078667028.html
Project Second Life----1978 c35
http://67-72chevytrucks.com/vboard/s...d.php?t=503961
tc4x4 is offline   Reply With Quote
Old 06-25-2012, 07:41 AM   #2
cletis
cletis's Avatar
Re: Ford 9 inch axle questions
9" are great, but I would reserve them for an all out performance build. If you want to run a 5 lug front and rear you would need Dodge stuff to keep the bolt pattern the same. Look for a set of 10 bolts?
I think I can, I think I can,
http://67-72chevytrucks.com/vboard/s...d.php?t=452601
cletis is offline   Reply With Quote
Old 06-25-2012, 11:17 AM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
Thats a great rear axle, but not the best choice for what you want to do. If it were me, I would find a 10 or 12 bolt from a GM truck that will drop right in place. Your going to have to build that one from the ground up.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 06-25-2012, 02:14 PM   #4
softballnrd27
Always a work in progress
softballnrd27's Avatar
It dependes on how much you get it for and what's on the inside. If it were a 31 spline with a trac-loc then it would be a good axle for what you want. If it is an open diff or 28 spline then I would avoid it bc it will cost more to upgrade it. You can build the 9" for real cheap and there are a ton of used parts out there for them. There isn't anything wrong with the 12 bolt either and you can get one ready to bolt in w/o any issues or upgrades.
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
