Old 06-24-2012, 02:37 PM   #1
57halfton
Lug Pattern
If im not mistaken the lug pattern on 71 & 72 halfton pickups is 5 lug on a 5 inch bolt circle ? Has anyone ever redrilled the front hubs and rotors and the rear axles and drums for a 5 on 4 3/4 lug pattern like a Chevrolet passenger car? Can it be done?
Thanks Guys , Gene
57halfton is offline   Reply With Quote
Old 06-24-2012, 11:33 PM   #2
67c10rustbuket
67c10rustbuket's Avatar
Re: Lug Pattern
You are correct it is 5 on 5" and you can re-drill them to pretty much any size but many machine shops (around here anyway) wont do the work due to liability issues. You will need to check the hub diameter also as these trucks have a larger hub that may need to be turned down to accept a 4.75 car pattern hub hole wheels.
And Welcome to the forum Gene! Later, Dan
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 06-25-2012, 10:06 AM   #3
b a king
Re: Lug Pattern
there is a guy on the h.a.m.b msg board that sells fixture for about 90.00 bucks to do your own re-drilling. if that helps any.
b a king is offline   Reply With Quote
Old 06-25-2012, 10:41 AM   #4
57halfton
Re: Lug Pattern
Thanks guys , Im thinking about selling my 57 halfton and getting a 69 to 72 halfton short bed either a 4x4 or 2 wheel drive. If I get a 71 or 72 2 wheel drive I have a set of 8 1/2 x 15 vintage American mags I would like run on it.
Gene
Old 06-25-2012, 11:05 AM   #5
crabbypatty333
crabbypatty333's Avatar
Re: Lug Pattern
I'm sorry to hi-jack your post, but I have a lug related question and just happen to see your post and thought I would add to this discussion rather than start a new thread.
I have a 68 C10. I expected to have 5x5 or 5x127 based on the following chart.
http://www.vehicle-bolt-pattern.com/...nce-guide.html
When I pulled the hub caps I found a 6-lug pattern (front and rear). I didn't measure yet, but I assume a 6x139.7 based on the same chart.
I believe my truck to be original (grandpas truck been in the family it's whole life). Might this have something to do with the "HD REAR SPRING" on the service parts identification tag? Can anyone shed some light on this for me?
Thanks,
1968 C10 LWB
Tulsa, OK
crabbypatty333 is offline   Reply With Quote
Old 06-25-2012, 11:29 AM   #6
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: Lug Pattern
All 67-70 Chevy trucks came with a 6 on 5 1/2 bolt pattern.In 1971 they changed to disc brakes and a 5 on 5 lug pattern,except for 4X4 and some f the larger trucks.There were many wheel options in both patterns.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 06-25-2012, 11:56 AM   #7
crabbypatty333
Re: Lug Pattern
Thanks PD. So basically that chart I found on the internet wasn't correct. Shocking. I was certain that everything I read on the internet was true! Thanks for clearing that up for me.
1968 C10 LWB
Tulsa, OK
