Old 06-25-2012, 09:50 PM   #1
x ReAcT x
Swapping the 4.3L to a RamJet 350 predicament
First of all i must say i love this website, when i began my frame off i knew nothing about these trucks, and now i know where every damn bolt goes. So i want to thank everyone for the help. So heres my latest situation. Ive got the frame rolling and now its time to put the drivetrain in. Im getting a killer deal on a RamJet 350 ($5500.00)so im curious if the bellhousing on my sm465 transmission will bolt up to the new v8 engine and also i dont know if the engine mounts will have to be moved forward, back, or hopefully stay in the same shape? Ive been searching the forum like crazy and i havent found any solid info yet. And i know this really has nothing to do with my post but N2TRUX ramjet setup is beautiful, im sure everyones already seen it but wow great looking truck.
1986 GMC K15 4.3V6/SM465/NP205
will be converting to
5.3LS E-ROD/AA adapter/SM465/NP205
10 Bolt Axle Rebuild Tutorial:
http://67-72chevytrucks.com/vboard/s...d.php?t=536415
x ReAcT x is offline   Reply With Quote
Old 06-25-2012, 10:04 PM   #2
86c20
86c20's Avatar
Re: Swapping the 4.3L to a RamJet 350 predicament
as far as i no they are all the same expete the l6 the monts have to move for those i think. the bells should also be the same if not there are a ton of those trans out there and you can get one ez same as fly and clutch
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph
1985 k30 "the ice cream truck from hell" no rust az truck
197-8??? c30 "ramp truck" 454
1978 monte carlo 350 350th with 2.73 gears. no rust. sc car
86c20 is offline   Reply With Quote
Old 06-25-2012, 10:07 PM   #3
x ReAcT x
You just solved all my problems thank you, ill go ahead and order the engine.
Old 06-26-2012, 07:20 AM   #4
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
A 4.3 has the same bolt pattern as a 350 SB. It's a direct swap. All accessories will fit too. Motor mounts will also swap. Basically, you're adding two cylinders.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 06-26-2012, 07:50 AM   #5
C-10 simplex
Please explain further concerning the engine mounts; Can the frame mounts and engine mounts be re-used and in the exact same positions?
C-10 simplex is offline   Reply With Quote
Old 06-26-2012, 09:03 AM   #6
rs72z
rs72z's Avatar
Yes. The 4.3 is just a v8 less the front 2 cylinders. The mounts are all the same including acc.
___________________
78 ccsb dually
5.3
4l60e
http://67-72chevytrucks.com/vboard/s...d.php?t=491551
rs72z is offline   Reply With Quote
Old 06-26-2012, 12:53 PM   #7
KQQL IT
At the body shop.
KQQL IT's Avatar
You may need a flywheel. I think a ramjet come with a flexplate
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
Old 06-26-2012, 01:34 PM   #8
rs72z
rs72z's Avatar
Good point. I'm not sure how the 4.3 flywheel is weighted.
___________________
78 ccsb dually
5.3
4l60e
Old 06-26-2012, 11:02 PM   #9
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by x ReAcT x View Post
........ And i know this really has nothing to do with my post but N2TRUX ramjet setup is beautiful, im sure everyones already seen it but wow great looking truck.
Thanks for the kind words. Roger at RPL did an awesome job on the install...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
