"Junkyard Dog"
![]() Join Date: Jan 2008
WTB SBC High perforance engine parts
Looking for some sbc parts for a future build. Here's a list off parts I need. I'm really only looking for new stuff or some like new with minimal use. Let me know what you have. Thanks, Tom
ARP head stud kit for standard cast iron heads Comp Cams Roller lifters Comp Cams or ARP 7/16 rocker studs Comp Cams 1.5 or 1.6 rockers or Jesel shaft system Circle track 7-8 qt. oil pan 750 or 850 Holley HP Tall Aluminum Valve covers
72 C-10 Cheyenne Super LWB, Vortec 427,TH700, 3.73 posi, tach, tilt, AM-FM,Frame off in process. http://s289.photobucket.com/albums/l...t=7eae161e.pbw 88 Monte Carlo SS bought new only 10k miles. 73 Chevelle SS 454 had since high school. 74 Camaro Z28 350 AT numbers matching, Black on Black. 73 El Camino SS 350 4sp. 70 Chevelle SS 396 4sp, number matching with LS6 454 69 Chevy C30 Car Hauler 86 K20 383 4sp 4" lift frame off restoration. http://s289.photobucket.com/albums/l...t=1b1082d3.pbw Last edited by tll74; 06-26-2012 at 12:23 PM. |
"Junkyard Dog"
Re: WTB SBC High perforance engine parts
ttt
72 C-10 Cheyenne Super LWB, Vortec 427,TH700, 3.73 posi, tach, tilt, AM-FM,Frame off in process. http://s289.photobucket.com/albums/l...t=7eae161e.pbw 88 Monte Carlo SS bought new only 10k miles. 73 Chevelle SS 454 had since high school. 74 Camaro Z28 350 AT numbers matching, Black on Black. 73 El Camino SS 350 4sp. 70 Chevelle SS 396 4sp, number matching with LS6 454 69 Chevy C30 Car Hauler 86 K20 383 4sp 4" lift frame off restoration. http://s289.photobucket.com/albums/l...t=1b1082d3.pbw |
![]() Join Date: Feb 2008
Think I might be able to help you out with some of the parts. I was going to use these parts to build a 383 for my truck, but I found a deal I couldn't pass up. I wound up buying an assembled 383 engine from a guy locally and couldn't return these parts. All of it is brand new unopened and factory sealed.
12-432-8 - COMP Cams XR282 HR Xtreme Energy Retrofit Camshaft 853-16 - COMP Cams High Energy Hydraulic Roller Lifters 1602-16 - COMP Cams Ultra Pro Magnum Rocker Arms 7609-16 - COMP Cams Magnum Pushrods 2100 - COMP Cams Magnum Double Roller Timing Set Also have a Quick Fuel SS-680-VS carb brand new in the box. Will also wind up with a set of AFR 195cc heads too. Just need to pull them off the motor I purchased. They might as well be brand new, installed new and engine never fired. They have had upgraded valvesprings for a solid roller cam. They are pre-eliminator heads, but still outflow Edelbrocks and things like that. I just got the flow specs from AFR yesterday. Thanks - Chad
1967 Chevy SWB 1972 Chevy SWB 1972 Chevy SWB K20 4x4 1991 Ford F-150 2013 Dodge Ram 1500 4x4 |
"Junkyard Dog"
Thanks Chad for your reply! I guess I should have given a bit more info as to what I needed. I'm building a new 421 cid (.875 stroke in a 400 block at .030 over) power plant for my stock car. I need a solid lifter roller with about .630-.660 lift and about 268-275 @ .050, and 106 LSA. Your studs are 3/8 and with that much lift I need 7/16. Now, your AFR heads are of interest. I would like to know about them and price. I just sold a buddy a 355 short block that is looking for a cam and valve train. He is building it for 71 El camino weekend pavement pounder. Let me know what you want $$ and I'll let him know. Thanks, Tom
72 C-10 Cheyenne Super LWB, Vortec 427,TH700, 3.73 posi, tach, tilt, AM-FM,Frame off in process. http://s289.photobucket.com/albums/l...t=7eae161e.pbw 88 Monte Carlo SS bought new only 10k miles. 73 Chevelle SS 454 had since high school. 74 Camaro Z28 350 AT numbers matching, Black on Black. 73 El Camino SS 350 4sp. 70 Chevelle SS 396 4sp, number matching with LS6 454 69 Chevy C30 Car Hauler 86 K20 383 4sp 4" lift frame off restoration. http://s289.photobucket.com/albums/l...t=1b1082d3.pbw Last edited by tll74; 06-28-2012 at 01:59 AM. |
PM sent on the heads.
