Old 05-17-2003, 04:44 PM   #1
^No[z]
Bad idle =\ ...advice?
Well, contrast to the topic, I dont mean idle when I start the truck, but Ive been having a problem for quite a while now...
Usually doesnt happen unless I travel more than 8-10 miles, but usually once the truck is warmed and I have been drivin for a bit in speeds > 50mph and I come up to the stop I idle real rough (for lack of a better word) the whole truck vibrates and sometimes it dies on me and have to restart...I can usually avoid it from dyin by keepin the rpm's up or shifting to neutral while im at a light (auto tranny) and its even worse when I have the a/c running on it...any thoughts?
^No[z] is offline   Reply With Quote
Old 05-17-2003, 04:55 PM   #2
MSL
MSL's Avatar
Sounds like you need to adjust your idle up. what carb do you have. you might need to do some tunning.
MSL is offline   Reply With Quote
Old 05-17-2003, 05:32 PM   #3
^No[z]
I had it adjusted like 6 months ago, =\ and its the q-jet
Old 05-17-2003, 09:17 PM   #4
^No[z]
^bump ...anyone?
Old 05-17-2003, 10:38 PM   #5
apstguy
LED King
apstguy's Avatar
Stuck EGR valve? Test it by taking and plugging the vaccuum hose that goes to the EGR valve. Might just take out the valve and see if it is stuck inside as well.
Tyler
1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles
2006 Ford Focus ZX3 5-speed Stick
2016 Chevy Spark EV
Gone: 2002.5 VW GTI 24v VR6
Gone: 2008 VW R32
apstguy is offline   Reply With Quote
Old 05-17-2003, 10:39 PM   #6
apstguy
LED King
apstguy's Avatar
Oh just remembered - a stuck PCV valve will do that too. Take the PCV valve out and shake it. If it doesn't rattle replace it.
Tyler
2016 Chevy Spark EV
Gone: 2008 VW R32
Old 05-17-2003, 10:50 PM   #7
^No[z]
oh, sorry btw my truck is a 79' c10 stepside 350/th350, q-jet
Old 05-18-2003, 01:27 AM   #8
jimfulco
Have you tried to re-adjust the idle at the time it's acting up?
jimfulco is offline   Reply With Quote
Old 05-19-2003, 07:31 PM   #9
pkbinplano
pkbinplano
pkbinplano's Avatar
how bout a stuck choke ???
http://www.picturetrail.com/gallery/...7496&members=1
84 chevy silverado aka The Bananna Boat
pkbinplano is offline   Reply With Quote
Old 05-20-2003, 03:22 PM   #10
bpmcgee
bpmcgee's Avatar
Don't forget that for an automatic, you're supposed to set your idle speed with it in gear, and with teh A/C (if any) running.
Brian
bpmcgee is offline   Reply With Quote
Old 05-21-2003, 03:11 AM   #11
jimfulco
& completely warmed up.
