Old 06-27-2012, 10:35 AM   #1
biohazardbill
sbc to bbc swap
Truck I have currently has a sbc in it, we are contemplating putting in a big block. What is the most efficient way to do this? I would like to run tall valve covers if possible. Slide exisitng mounts forward in the cradle? Get different mounts all together?
Thanks in advance.
biohazardbill is offline   Reply With Quote
Old 06-27-2012, 03:13 PM   #2
jhrusk
Re: sbc to bbc swap
I put a bbc in my 65 years ago, I used the later truck mounts like 73 and up, I also used 69 camaro 1 3/4 headers.I had moroso chrome valve covers,If I remember correctly I inatalled the mounts on the engine and posotioned the engine were it would clear the firewall and then drilled 3/8 holes for the frame mounts,I did have to ding the headers in a couple of places but overall it was not that bad.Hope this help.
check out SANFORD build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=522019
jhrusk is offline   Reply With Quote
Old 06-28-2012, 12:10 AM   #3
Captainfab
60-66 Nut
Re: sbc to bbc swap
While I prefer to use the '73 and up motor mounts, you can also use the '68-'71 truck motor mounts and brackets, They will bolt right into the '63-'66's, but I don't know if you can run tall valve covers without modifying the firewall. When I built my Suburban, I fabricated custom brackets and used the '73 and up mounts and the upper bracket, also known as the 'clamshell'. I did this because I wanted to run M/T valve covers on it. I moved the engine forward aprox 2" from the original location.
Old 06-28-2012, 10:37 AM   #4
66farmer
66farmer's Avatar
Re: sbc to bbc swap
If you need A set of headers for your BB. I have a new set for sale.
66farmer is offline   Reply With Quote
