Old 06-27-2012, 11:50 AM   #1
DetroitIron
DetroitIron's Avatar
How much and where to add PAG oil..
I have replaced my entire AC system with new stock components and added a high pressure cut out solenoid....before drawing a vacumn and charging, I need to know many oz of PAG oil to add and whether it all goes in the compressor or??? Thanks,
_______________________________________________
1985 Chevy Scottsdale K20 350 with 700R4 running 3.42 gearing aka "The Honey Badger"
1993 Silverado C3500 Ext. Cab Dually 6.5 turbo diesel
DetroitIron is offline   Reply With Quote
Old 06-27-2012, 12:27 PM   #2
Edahall
Re: How much and where to add PAG oil..
Is your A/C system entirely free of oil? If so, refer to the following for the correct amount of oil to use.
http://www.napabeltshose.com/downloa...s&view=napa_hc
Assuming your truck has an A6 compressor, you'll need 10 oz of PAG oil. This is also assuming that the A/C system has been properly cleaned, and new accumulator / filter drier has been installed.
Add about half the oil to the compressor and the other half to the drier.
I hope you're not using one of those vacuum machines that hooks up to an air compressor.
Send me a PM if you're interested in a common off the shelf refrigerant that works better than R12 and less costly than R134a. IMO, R134a was a step backwards from R12.
1990 ¾ ton 4x4 Chevy Suburban
-Cummins Diesel - 12 valve - factory rebuilt
-6 speed bullet proof manual transmission - NV5600
-Gear Vendors Overdrive - HX35 Holset Turbo
-NP205 iron transfer case
-3.73 gears -2" Lift
Edahall is offline   Reply With Quote
