Old 06-27-2012, 12:24 PM   #1
Durney
Chrome lockstrip install question...
Which works better...
Install the lockstrip (and gasket) on the glass then rope it all in the opening at one time?
OR...
Rope the seal and glass in , THEN put the lockstrip in. (yes I have the proper tool)
I would think that the second way would be easier to rope it in given the glass will be looser in the gasket, but it sure would be easy to get the chrome corners (rear) fitted ahead of time.
Durney is offline   Reply With Quote
Old 06-27-2012, 06:47 PM   #2
Telecasterjoey
Re: Chrome lockstrip install question...
Ive done it a few times and each time I put the lock strip in after. I put the seal on the truck then wrestle the glass in then put in the strip I use lots of soapy water or wd40. Good luck!
Telecasterjoey is offline   Reply With Quote
Old 06-27-2012, 07:51 PM   #3
Gordonr1973
Home Built '87
Gordonr1973's Avatar
x2
When I had mine done the gasket was new & was so 'fat' that putting the lockstrip in after was the only way it would fit.
The fellow said that once the truck sits in the sun for a few months, the gasket will conform better to the truck so removing the windshield will not be as hard to put back in again with that gasket (in case of a repaint).
So I guess it depends too on whether your gasket is new.
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 06-27-2012, 08:16 PM   #4
rs72z
rs72z's Avatar
As far as i know it's not possible to install the glass with the lock strip installed. It's hard enough with it out. That's the purpose of the strip to lock the glass in the rubber.
___________________
78 ccsb dually
5.3
4l60e
http://67-72chevytrucks.com/vboard/s...d.php?t=491551
rs72z is offline   Reply With Quote
Old 06-27-2012, 09:11 PM   #5
kalbert
I think you're right. I don't think it's possible either. Gasket, window, then lock strip. And lots of soapy water.
kalbert is offline   Reply With Quote
