Old 06-27-2012, 01:54 PM   #1
mikesacs
mikesacs's Avatar
automatic shift indicator
I just installed a 700r4 and updated the column shift indicator for the 4 speed transmission. I think I'm missing the red plastic indicator (pointer) that presses into the column. I have a few pictures, but you need to know what to look for. Anyone know where to get one or a photo so I can make one?
mikesacs is offline   Reply With Quote
Old 06-27-2012, 09:26 PM   #2
hugger6933
Re: automatic shift indicator
I would say just about anyone that sells stuff for these truck should have one, check with you favorite supplier. I will also tell you I had two of those break and the shifter would like lock up going from neutral to reverse and it did it on both that broke . It was a booger roo to get them out but that fixed the shifter. Keep that in the back of your mind incase it ever happens to you
hugger6933 is offline   Reply With Quote
Old 06-28-2012, 09:17 AM   #3
mikesacs
mikesacs's Avatar
I found this in the catalogs, but the pointer doesn't look correct. It says it has adhesive to stick the pointer to the column. Mine looks like it would be a press fit into the bump on the column.
