Old 06-27-2012, 04:10 PM   #1
McMurray76
Body Swap
I am planning to put an '86 C20 cab & bed on a '77 K20 chassis. What kind of problems should I be expecting? THANKS
McMurray76 is offline   Reply With Quote
Old 06-27-2012, 07:02 PM   #2
ghettoluxury
ghettoluxury's Avatar
Re: Body Swap
Make sure you use the body bushings for the 77. Other than that you need to use the front bumper brackets from the 86 if you are using 80's fenders. It is a straight forward process.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 06-27-2012, 08:00 PM   #3
RandyP
Getting Old; Going Broke
RandyP's Avatar
Re: Body Swap
Is the C20 a standard transmission or an auto? Transmission tunnel might be your only real obstacle.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 06-28-2012, 02:36 PM   #4
McMurray76
Re: Body Swap
Thanks guys! Ghetto, No front bumper, it's a plow truck. Randy, the c20 was a low hump but I unbolted the high hump from the K20 used it as a pattern to cut out the low hump. The rear cab mounts look different, am I going to have to do some fabrication on them?
