Removing '78 Scottsdale 20 emblem
Yo! Y'all!
Sorry I've been so scarce, but I'm just finishing a year long addition onto the house. FRANKENTRUCK is finally getting a primer coat. Hardly looks like the old ugly truck! No more bovine-crushed rear quarter, no more bullet hole! I'm finding conflicting information in my searches for information as to how to remove the fender emblems. My 1978 Scottsdale 20 emblems are attached with speed nuts. Are there any secrets, other than removing the outer fender, to removing and replacing these emblems for painting? Thank you all very much for all your help in the past,...FRANKENTRUCK would not be the truck that it is, if not for all your technical help and support! It's one hell of a truck that you helped me build from scratch! I'll post pics via the FRANKENTRUCK thread once I've got it primer gray. Thanks, Todd.
'78 3/4 ton 4x4 custom "Todd-built" FRANKENTRUCK! |
Re: Removing '78 Scottsdale 20 emblem
No.....that I have found, i took the fenders off to do mine.
As I suspected,...thanks much.
Todd.
Assuming you want to keep them, other than removing the fenders you'd have to find someone with very skinny arms (and two elbows).
If you do not need to keep them you can whack them with a hammer (vertically) and it will shear the pins, allowing them to fall off. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
Howdy Keith!
Thanks. These will easily be refurbished (polished and new paint in the inserts), so I'll be removing the fenders to get them off and back on again (Yuk!). Let me ask this,...with that in mind, would final paint be best with fenders off? Then, once the paint has dried, the emblems could be attached, and then the fenders bolted to the painted vehicle. Rather than removing/replacing freshly painted fenders. Thoughts? Thanks, Todd.
#6 | |
K
