cannot collapse intermediate shaft...
i completley removed the plastic 'rivets' let it soak with pb blaster, and this is day 3 i still cannot get it to collapse, any tricks any one knows of?
A guy with a truck
Re: cannot collapse intermediate shaft...
How did you remove the plastic? I usually use a propane torch and cook 'em out. The plastic will swell and come out the holes looking like worms. Burn 'til it stops oozing. Whack it with a big hammer 'til it collapses...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
I had to get a little aggressive with mine, I had the shaft completely out of the column. There's no way mine would have ever moved without beating on it a little.
Super Blue - 1968 C-10 Short Stepside
Fastburn 385, 4-Speed Sag. on the Column, Coleman 9" Floater w/Detroit TrueTrac |
i drilled them out and used a scribe to get the remainders out, and i have soaked it, beat it on the ground very hard, soak it again beat it on the cement some more and still wont budge, ill keep trying, i dont want to hit too hard and bend or break the rag joint
nevermind i was being a little girl and just had to hit it even harder, the thing was covered in rust.
Good information.
1968 C10, 250, L6 4spd OTF, Fleetside Upgrades: Power Steering .......................____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ |
