![]() Join Date: Aug 2011
I'm search challenged
I know I have seen several posts about swapping out the rear axels to 5 lug wheels and just can't seem to locate them.
Would some kind hearted soul please lead me to them? Thanks in advance.
http://s994.photobucket.com/albums/af62/ScottAz2/ |
1961 crewcab
Re: I'm search challenged
not sure on a post, but speedway motors sells a kit to do the swap-63-66
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
Geeez at $499 and the time and trouble to do the conversion wouldn't it be cheaper to just replace the whole rear end?
#4 | |
67-72 parts collector,…
![]() Join Date: Nov 2002
Moser Engineering, and Early Classic Enterprises also sells axles.
60-66 Nut
![]() ![]() Join Date: Mar 2007
Summit racing offers an inexpensive conversion axle. In addition to the suppliers lolife99 mentioned, drivetrain specialties is another source.
If your differential is a '63 or '64 model of the truck 12 bolt, you will also need the 30 spline conversion side spiders. That does drive the cost up. Also if you are searching for something and can't seem to find it, check out the 60-66 FAQ index at the top of the main 60-66 page. There's links to lots of good info in there.
![]() Join Date: Feb 2001
Hope this helps ...
6 lug to 5 lug rear axle swap http://http://67-72chevytrucks.com/v...d.php?t=456299 5 lug rear axle conversion (66) http://67-72chevytrucks.com/vboard/s...d.php?t=399080 what did i do wrong? 63 c10 axle swap with 71 not working out http://http://67-72chevytrucks.com/v...d.php?t=530971 Rear end question http://67-72chevytrucks.com/vboard/s...d.php?t=527204
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
One quick question before I research all the information you all have given me.
A friend of mine owns a machine shop here. Is there any reason I just can't take the existing axel to him and have the new bolt pattern set into these axels? Do I really have to change everything?
#8 | |
60-66 Nut
Yes that can be done. But before you do, closely check the wheel bearing surface of the axles to see if they are worn. If they are work very much, they should probably be replaced anyway. Also you will want to weigh the cost of the old axle machine work versus what a set of conversion axles will cost.
I went to the salvage yard today to pick up some odds and ends and asked the kid that owns the place about rear ends that are a direct bolt up to the 64.
He says the 71 was the 1st year with rear disc brakes and it was a direct bolt up and the same size as the old rear end in the 64. I seem to recall that it is 1.2 inches wider than the original? Or am I confused from reading too many posts about swapping too many parts? Is there a rear end with 5 lugs and disc brakes that is a direct bolt up to the 64 that has the trailing arms?
I think your salvage yard guy was mistaken. 1971 first year for front disc brakes i.e. 5 lug. As far as axle width- I am not certain.
60-66 Nut
The late 1970 to '82 truck 12 bolts were 1.5" wider than the earlier truck 12 bolts. I have not seen any truck rear ends with factory disc brakes until the '90's sometime. Your '64 has the longer panhard bar. The '65-'72 panhard bar will work, but it will need a slight bend to line up with the frame bracket on your '64 frame.
There are a couple rear ends that have disc brakes that are close to the original width, but they will need the trailing arm mounts and a panhard bar mount welded on. The '94-'96 Impala SS and Caprice 9C1 rear end is one that will work. However they are not as strong as the truck 12 bolt. You can always add disc brakes to the 12 bolt.
Hey McCoy, I have a 70 Chevelle rear end complete ready to go if you're interested. 2.73 gears w/5x4.75 bolt pattern. I believe it's about 1/2" wider than our stock axles. You would have to do some machining to get the old mounts off and weld yours on. PM me if you're interested.
1962 GMC 1/2 ton stepside longbed, 305 V6, Muncie 3spd HD tranny, stock rear end, rolling resto! |
