Old 06-27-2012, 11:49 PM   #1
425HP409
425hp409
425HP409's Avatar
72 Wiring Problem
I am installing all new wiring harnesses in a 72 with AC and there is a harness coming out of a round plug to the left of the firewall harnesses that was not connected to anything. I don't have one like this in the new harnesses and wonder if I am going to need it. I am also installing a new engine, so don't have it installed yet to match all the wiring up until tomorrow. If some one has a truck that I can look at, I would appreciate the chance to do so. I am in Frisco.
Charles Haley
Frisco Automotive
972-335-9823
Charles
68 SWB, Dad bought new, now 396 & factory ac
64 Impala SS, 409 425HP, 4 speed AC
64 Bel Air Wagon, 400 Small Block
57 Bel Air all original 283 w/Factory Air
77 GMC Sprint, 454/425HP
67 Olds 442, all original
90 ZR1 Corvette
425HP409 is offline   Reply With Quote
Old 06-28-2012, 07:06 AM   #2
KEL
72 GMC
KEL's Avatar
72 Wiring Problem
Not sure where you mean.
Take a look at this . .
KEL is offline   Reply With Quote
Old 06-28-2012, 07:43 AM   #3
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: 72 Wiring Problem
Here are a few threads wit pictures. It might be this --Transmission controlled spark
http://www.google.com/custom?domains...D%3A1%3B&hl=en
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 06-28-2012, 08:26 AM   #4
rsavage
rsavage's Avatar
The smaller round hole to the right and above the fuse block connector (as you are standing looking into the engine compartment) is for a light brown wire that goes to the gas gauge sender. The above diagram photo doesn't seem to show it. Also on the tunnel part of the firewall shown (again as you are facing it from the front of the truck) the uppermost hole on the slant is for the oil line, and the one underneath it for windshield washer tubing. The hole on the flat of the the tunnel near where the throttle cable exits is for the rear light harness.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 06-29-2012, 08:50 AM   #5
Todd Hepler
Rottenwood Garage Member
Todd Hepler's Avatar
I have a similar harness on my '72 with AC. I think its there to run the AC idle circuit on the factory carb as well as the factory electric choke.
I'm not 100% sure as I yanked these items and did not pay attention to their function.
Todd
Todd Hepler is offline   Reply With Quote
Old 06-29-2012, 09:01 AM   #6
LEEVON
Moderator
LEEVON's Avatar
Let me go out to my truck and check for you...
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 06-29-2012, 10:26 AM   #7
rsavage
rsavage's Avatar
I have never seen a factory electric choke. I believe they were all divorced chokes with no wiring to them. 525409hp - can you take a photo of the plug?
1961 C1 Corvette
2021 Durango RT 5.7
Old 06-29-2012, 10:34 AM   #8
NoNeck
NoNeck's Avatar
NoNeck
2016 RAM Laramie HEMI
1966 Fairlane GT/A, 390/335 HP
If it costs you a dollar to make a friend, KEEP THE DOLLAR.
If it costs you a friend to make a dollar, KEEP THE FRIEND.
NoNeck is offline   Reply With Quote
Old 06-29-2012, 03:29 PM   #9
Todd Hepler
Looks like TSC and associated wiring
see post at http://67-72chevytrucks.com/vboard/s...d.php?t=297960
All of these wires match up with what I unplugged on mine
Todd
Old 07-07-2012, 10:38 PM   #10
72 K20
72 K20's Avatar
On all 3 of my '72 trucks and the '71 parts truck the fuel gauge sender wire comes out of the top of the fuse panel under the dash, runs along the left sill plate ( along with the dome light and cargo light wires,) and then to the fuel tank sender.
2 are AC & automatic trucks, the other 2 are non-AC with manual trans, 3 C20's, 1 K20.
I just went out and looked,, all 4 trucks have a plug in that hole .
Don't know what wire you are referring to.....
72 K20 is offline   Reply With Quote
