Basically I am looking to install a 1982 Trans Am posi disc rear end and would like to see pictures on converting over to leaf spring setup and how the stock steel brakes lines & soft lines are set up on these rears. All of my original brake lines are missing..........need a good picture of how they are setup. Thanks! Specifically looking for those running this setup on 55-59 pickups.
1957 Chevy Pickup 1/2T, stepside, big window, 77' Camaro subframe, 3rd gen Firebird rearend w/3.23 gears & disc brakes, 66' 283cid, TH350 auto, everything else is original |
Re: 82-92 Camaro/Trans Am disc brake rear ends............who's running them?
Is there some reason you are picking that rear end? The early (pre-89) disc brakes are horrible and you'd be better off with drums. This is coming from someone who owns 12 of them currently... It's also a weak 7.5" 10 bolt.
Its what I have available to me, I plan to not be making any higher horsepower than what that rear saw with a V8 stock. I have talked to a few folks who are running similiar setups and are happy. This is a cruiser........not a tire-roasting drag truck.
#4 | |
gets board easy.......
however, i did convert the brakes to a stock 64-67 nova 8.2 rear end and was happy how the discs worked. ' |
well for a cruiser you should be fine. i wouldnt tow a big trailer with it.
Truck will be running empty in the bed most of the time and V8 used is making around 200hp
While I'd tell you the 90-92 rears are a tad better, using what you have is OK if you don't overload it. Been driving on mine in my third gen for 20 years. This guy has the setup you're looking for, his is the super rare 9 bolt third gen rear but the setup is identical...
http://67-72chevytrucks.com/vboard/s...=501998&page=8 Hope that helps.
56 GMC BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=368649 69 long bed Chevy turned 67 gmc jimmy roadster: https://67-72chevytrucks.com/vboard/...d.php?t=851167 |
#8 | |
Hey folks! I tried mounting some wheels on my 83' Trans Am rear yesterday only to find out that my SAE lug nuts are not threading on. I tried some other standard lug nuts with no luck. I looked closely at the wheel stud ends...........there are "M"'s stamped on the ends. Is this an obvious marker that means metric lug nuts? The bolt heads on the diff cover also have stamped "M"'s. I am feeling confused about whether these rear ends were metric or SAE, even though they were factory American Pontiac parts. Does anyone know the scoop on these axles?
They are 12x1.5 Metric.
Awesome! Thank you. I just did a quick internet search and learned that these studs are metric. Confirmed my question.
If you need any more info on these rear ends check out Thirdgen.org
#13 |
nw: i have an 86 trans am rear end with disc brakes under mine
my diff cover looks diferent it's a 3.27 ratio that was used in 90 ta's that yr spring pads and bottom plate came from a trailer supply house u-bolts from a local suspension shop stock 58 shock mounts same brakes as the other ones. look in my thread for more info ![]() ![]() ![]() ![]() i used the 86 sway bar by heating and bending the ends to fit the frame ![]() i also incorporated the torque bar to minimize diff roll ![]() ![]()
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
#14 |
Hey _Orge,
You don't have a 10 bolt, you have the Aussie 9 bolt. The gears aren't out of a 90 TA, 89 at latest as 89 was the last year GM used the 9 bolt. |
#15 |
I think what Ogre was saying is that his rear end is out of a 1986 trans-am, and only 90 trans-am's in 1986 came with his particular rear diff.
#16 |
I don't know where he would come up with that number being that the number of 9 bolts installed in 86 is basically an unknown number, much less how many had the 3.27 ratio. But reading back, I believe you are correct in what was meant.
#17 |
really don't know much about the rear end, but one of the camaro guys over at hotrodders.com was interested when i said it had the 3.27 gear
all he said was that it was experimental rear end for that year made by borg warner my numbers were off, according to http://www.thirdgen.org/1986-pontiac-firebird there were only 50 produced as test cars they may not have made it into production, the junk yards are full of non-production cars around here and yes it has the factory 3.27 tag on it still
#18 |
Not experimental at all, they started putting the 9 bolts in the F-bodies in 1985. You don't have one off of a test car, I would bet you my truck on that. It may have been swapped onto a 86 Trans Am from a 87 or later 350 with the L98 and G92 package.
#19 |
Hey guys......... can anyone show me a pic or explain how the rear disc caliper pads attach to the piston cylinder? I noticed a retaining clip on the piston cylinder and wanted to make sure it is attached correctly. Would really like to see how the rear axle brake lines are ran also. These rear calipers take banjo fittings and I need to see an example. Thanks!
#20 |
Anyone know how this pads attach on the piston side?
#21 |
Re: any ideas?
Bump....... still looking for info on how the brake pads attach and e-brake setup.
#22 |
I used a mid 70's Camaro 10 bolt (I believe it was from a '74) but upgraded it with '91 disc brakes.
Robert C. 1950 3600 3600 re-do, shortening it up If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. |
#23 |
the oem pad had a clip on to attach to the pad to the caliper
don't worry about it as the residual pressure valve you should be running will keep the pad in close proximity to the disc the e-brake has a spring and a cable to actuate the e-brake the calipers on these is the same one mounted in front and one mounted on back of the backing plates this is where they go, i don't have an e-brake ![]() ![]() the caliper has an internal ratchet that keeps the e-brake adjusted close to the back of the piston. when you need to re-pad the caliper the ratchet needs to be disengaged so that you can get the piston back as for a banjo fitting; any parts store can get one, but the rod supply stores will have the ones you can hook an AN fitting to a hose. i ran a flex line from the frame to each caliper, but you can also run a single flex line to the diff and hard line to the calipers
#24 | |
#25 | |
