horn question?
My horn was never connected in my truck and today I tried to fix it. I have a Grant steering wheel. I changed the relay and it still does not work. How common is it for the horn not to work? I might just go to the junkyard and pick one up later this week.
Robert Olson Transport
![]() Join Date: Oct 2002
Re: horn question?
IIRC grant makes a horn button and kit that goes with the wheel that you have to use
Re: horn question?
Have you checked to make sure it's getting a good ground? There's only the one wire that goes to the horn under the hood I believe.
Then yes, the horn kit for the Grants is about $20. But, you should be able to check and see if it work or not by touching the wire at the button to the nut or somewhere on the steering wheel.
1st - '68 long bed 2nd - '81 SWB Now - '86 SWB, Edelbrock 1406/stock 350/700r4 |
Re: horn question?
Your horns may be good. Just take the horns off the truck. Then hook a ground wire from the battery to the horn body. Then run a wire from the hot terminal on the battery to the terminal on the horn, and see of it works.
