Old 06-28-2012, 04:09 AM   #1
leddzepp
Moderator
leddzepp's Avatar
Question Can discolored factory gauges be polished out?
I was wondering if there is a way to polish out the "discoloration" that occurs on many OEM gauge numbers and letters and make them look new again? Here is an example of what I am talking about. The black background is not "perfect" on the gauge, but other than the lettering and hatch marks being discolored, it isn't too bad. I have seen many others where the discoloration is a lot worse.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 06-28-2012, 11:33 PM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: Can discolored factory gauges be polished out?
70 views and no responses....I guess not
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 06-28-2012, 11:36 PM   #3
70cst
70cst's Avatar
Ok...a bump
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 06-28-2012, 11:52 PM   #4
jocko
jocko's Avatar
yes. or maybe no. I was assuming you were referring to the plastic lens, which would normally be a yes. Then the first time I read, I thought you were talking about polishing the black. NOW I understand - the white stuff. Problem is, I don't know how the factory applies the lettering/numbering/white stuff - but it HAS to be after/on top of the black, so I would think you could lightly polish by hand, maybe with an extremely low grit type of polish - maybe just a little more abrasive than wax - or maybe start with a "cleaner wax" and slowly work your way towards sandblasting (just kidding, but that direction I mean). If you wouldn't use it as is, then it probably can't hurt to give it a try. Perhaps plastic lens polish or the stuff they use on headlights nowadays? Does anyone make new full background appliques?
Old 06-28-2012, 11:57 PM   #5
Lee H
Lee H's Avatar
I recently took a gauge like that to redline gauge works. They said the discoloration was actually rust under the paint and silk screen. They said the only way to clean it up was to restore the gauge. Not real expensive if they have the art work to reapply the markings. Very expensive if they have to create the art work.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 06-28-2012, 11:59 PM   #6
FirstOwner69
FirstOwner69's Avatar
I don't think so. As I recall, if you so much as rub the white printing on some of the gauges with anything damp it'll wipe off or, at best, smear. I think it is the big gauges (speedo and fuel). I'd hate to see what any compounds, or waxes would do. I have masked the orange area on the temp gauge and painted it without a problem.
FirstOwner69 is offline   Reply With Quote
Old 06-29-2012, 12:05 AM   #7
Duvall
Every time I have tried the white smears. I have tried everything from water to thiner. No luck with any. Lost patience and bought a new one. Good luck.
Duvall is offline   Reply With Quote
Old 06-29-2012, 12:37 AM   #8
1972RedNeck
1972RedNeck's Avatar
Why are all of my gauges like this one and get stuck a little bit to the C side? I thought is was just the air up here.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
