what size tire for front 4 1/2 drop ?
wondering what size tire will work with my front 2.5 dropspindle and one coil cut ( = about 4 1/2 " front drop).
rim is 4x4 truck 15x7 - steel 6 lug rear is bagged (about 4" drop) _ got 235-75-15's there. just worried about clearance issue. thanks in advance for suggestions. paul |
Re: what size tire for front 4 1/2 drop ?
I had the same drop and was running a set of 275/60R15 and had no problems. I have a 5 inch drop in the front right now and am running a 275/50R17 and am not completely sure if it is rubbing or not.
#3 | |
gonna be happy if these work because i did not want to pop for more tires right now. since i had these 235 75's its all good now. ![]() |
im running 225/75/ 15s on mine with a 7/6 drop with no problems.i made a carboard template to replicate the tire and disc break setup.
65c10 43,000 original miles ,230 stovebolt,powerglide,3" drop spidles 3" drop springs w/ half coil cut and 5 drop springs in back with 1 1/2 blocks... c notch soon to add hei offy 4 v intake and holley 390 ![]() |
