Old 06-28-2012, 03:39 PM   #1
CountryGirlT
CountryGirlT's Avatar
Unhappy Windshield washer not spraying?
Hey everyone! This doesn't bother me too much but when I need my windshield washed, the washer aint spraying washer fluid! I checked the hose and blew air through it, I can feel it coming out the other side so it's not clogged with dirt. The washer fluid is obviously full, and when I turn it on I can hear a little clicking sound... just nothing comes out! Anyone have ideas?
Should I get a new washer pump?
CountryGirlT is offline   Reply With Quote
Old 06-28-2012, 04:58 PM   #2
Themadmek
Themadmek's Avatar
Re: Windshield washer not spraying?
Sounds like it is either the pump or the relay.
Themadmek is offline   Reply With Quote
Old 06-29-2012, 01:49 AM   #3
oklalawnboy
oklalawnboy's Avatar
A "little" sound like a relay or a KaThunk like the pump kicked in but ain't a pumping? Mine had the Ka-thunk and I replaced the pump with one from Brothers.
72 Cheyenne super 10
08 3500 HD 4dr dually
12 ford flex (wifes ride)
76 Monte Carlo
83 Chevy short wide Silverado
96 Mazda Miata, 2000 Allegro Bus
oklalawnboy is offline   Reply With Quote
Old 06-29-2012, 01:57 AM   #4
Themadmek
Themadmek's Avatar
did the other pump fix the problem? I have had to replace the pump on much newer vehicles, a 2000 blazer, and my 70 year old Mom's car, a 1984 trans am, on both I could see the alternator volt gauge drop, I could tell it was the pump. I hope this info helps a little.
Old 06-29-2012, 06:25 AM   #5
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
All you need to do is to prime it up most likely. Take cap off and turn upside down. Attach a small funnel to it and fill with water, then work the pump. In no time at all, it should suck the water in and start to spray. Then just remove the funnel and put the cap back in.
As long as the clicking sound is there, that shows the pump is engaging. Other than the above, you can buy new O rings that go in where the hoses attach but try priming first.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
