Old 06-28-2012, 04:00 PM   #1
68gmsee
Active Member
68gmsee's Avatar
After market alternator and p.s. bracket info needed
Has anyone installed aftermarket brackets for the alternator and/or power steering?
If you have, please post some pics and also mention if you were satisfied with them or if you had to shim to make them align properly.
I'm working on a 350 engine that I bought and having trouble finding the original stuff that aligns properly so I'm leaning to aftermarket stuff even though I don't care for all the chrome.
Thanks.
68gmsee is offline   Reply With Quote
Old 06-28-2012, 08:40 PM   #2
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Re: After market alternator and p.s. bracket info needed
I used alan grove brackets on my 283 for the PS and ALT, he also has pulleys for sale. Cant get any pics at the moment, in transit. They worked well, no shimming required.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 06-28-2012, 08:45 PM   #3
68gmsee
Active Member
68gmsee's Avatar
Smitty
I'll check him out. If you can post some pics when you get a chance. Thanks.
Old 06-29-2012, 12:30 AM   #4
AustinScott
AustinScott's Avatar
Hey man,
check out post#10 in my photo build thread... "Link in my Sig below"
I have some good pictures of the Alan grove PS bracket & a summit racing alternator bracket. Both are mounted on the drivers side.
Let me know what you think, I have a lot more pictures & info if you or anyone needs any.
Good luck!
Scott
68-SWB, 327, hooker headers, spintec mufflers, disk brake 3.5/5 drop, buddy buckets, 200-4R, 2200 stall, 3.73 12bolt Eaton Posi,
My 68-SWB Photo Build Thread
All my Google Albums
AustinScott is offline   Reply With Quote
Old 06-29-2012, 12:39 AM   #5
colin_havens
colin_havens's Avatar
Im gong to install a March Mid-mount kit here in the next week or so. I will take some pic and post them up for ya
colin_havens is offline   Reply With Quote
Old 06-29-2012, 10:32 AM   #6
68gmsee
Active Member
68gmsee's Avatar
Originally Posted by AustinScott View Post
Hey man,
check out post#10 in my photo build thread... "Link in my Sig below".........Let me know what you think, I have a lot more pictures & info if you or anyone needs any.
Good luck! Scott
Thanks. That's an awesome truck and build! And I know who's going to lay claim to it in a few years.
Thanks much.
Old 06-29-2012, 10:39 AM   #7
68gmsee
Active Member
68gmsee's Avatar
Other than having trouble finding a complete untouched set still on the engine here's another reason I'm not crazy about the looks of the stock mounting brackets.
Original mounting brackets are just plain ugle to me. It seems to me that GM could have done a better job.
Old 06-29-2012, 10:43 AM   #8
68gmsee
Active Member
68gmsee's Avatar
Here's a try at modifying the ugly alternator top bracket. Surprisingly enough, the alternator stayed pretty solid with the bottom and front mounts.
Old 06-29-2012, 01:51 PM   #9
rsavage
rsavage's Avatar
The brackets you pictured are not from 67-72 chevy trucks. They are from a later version and that motor has a long water pump. On our trucks, the alternator is on the driver's side.
You could post a want to buy ad for a PS bracket set up, the correct pulleys, and the alternator brackets. You would need to change to a short water pump, and I am not sure if that later PS pump will fit the correct bracket so you might ask for the pump too.
Here is a pic of the correct alternator bracket set up. I don't have one of the PS pump bracket but it is cast and sits below the alternator with 2 bolts to the front of the block and one to the motor mount.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 06-29-2012, 05:57 PM   #10
68gmsee
Active Member
68gmsee's Avatar
I'm aware of the differences. It's a long story but it's for my 69 which originally was a six cylinder. I bought the long block pictured without any peripherals and I already had everything from another 77 engine that I had. Only problem I have is I'm not crazy about the stock brackets.
Thanks for the input. I'll save the pic to my truck album in case I go back to everything original.
btw: Awesome work you did on that Blazer.
Old 06-29-2012, 10:15 PM   #11
rsavage
rsavage's Avatar
68gmsee - sorry if I was giving unneeded info - I should have looked to see how long you have been on here before posting. I like the trimmed alternator bracket - looks muck better. Thanks for the complement.
1961 C1 Corvette
2021 Durango RT 5.7
