Old 05-17-2003, 08:02 PM   #1
72gmcshorty
72gmcshorty's Avatar
Finally solved wiring problem...sort of..
I have tracked down what was causing my turn signal and front yellow lights to come on constantly....the STEERING column!! Anyone know why the steering column would be a problem? How do I go about solvingthis problem?
1992 Gmc 2wd
1972 Chevy Blazer 2wd
72gmcshorty is offline   Reply With Quote
Old 05-18-2003, 01:04 AM   #2
jimfulco
That's where the turn signal switch is. First, find the electrical connector (flat, got several wires on both sides) that connects the switch to the under-dash wiring. Wiggle it real good or unplug it & plug it back in a couple of times. This cleans the connections a little. If this helps, take it apart & clean with contact cleaner, then a little silicone spray, & reassemble. If not, you may have a problem with the turn signal switch (a short, or a loose wire, etc.) beneath the steering wheel. I had a Ventura that had one so bad I had to put a jumper across the connector.
jimfulco is offline   Reply With Quote
Old 05-18-2003, 01:30 AM   #3
jef5150
Inline 69
jef5150's Avatar
ive had same problem,except ,,,my rear parking lights would not work when i bougt it 2 months ago,,,,then when i got it in the garage,they worked,,,then they didnt,on and on,,,i finally found out i had a short in the turn signal harness{switch}and every time i got in and out of the truck while working on the cab i was hitting the turn signal with my arm,,,35$ later its fixed
jef5150 is offline   Reply With Quote
Old 05-18-2003, 10:48 AM   #4
70c10
67-72 Addict!
70c10's Avatar
I had similar probs last year and it was the turn signal switch. Now the lights are brighter than ever.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
