06-28-2012, 11:06 PM | #1 |
Dark green 1971 Dark Green Lap Belts 6 pieces Decent Driver Quality
I pulled these out of a 71 C10 truck I parted and decided not to use them after all. The retractor boot is split on the passenger side. There is a scrape on the driver side boot, but it is not split. There is primer overspray on both retractor boots. Both retractors work as intended. The webbing on all belts is in good condition. I have not cleaned them any, but would assume they would come out pretty nice with some woolite. One of the "GM" stickers is peeling on one buckle. The other two stickers are fine. The plastic on the buckles is in good condition with no cracks. The center male belt tab has some rust from being under the seat for years. There is no substantial rust on the other buckles or tabs. I planned to find another set and make one really nice set using these as "donors", but decided to build a red truck with black belts. $40 shipped to lower 48
06-29-2012, 08:01 AM | #2 |
Re: Dark green 1971 Dark Green Lap Belts 6 pieces Decent Driver Quality
The photos show the worst of the belts, btw. Also, these are dark green in case you didn't see it in the title.
Posted via Mobile Device Posted via Mobile Device |
06-29-2012, 08:04 AM | #3 |
Carpe manana
Sport/Truck may be interested in these for the center belt as he is looking for one. I just sent him a PM.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
06-30-2012, 09:10 AM | #4 |
Sierra Grande Club
Thanks for the heads up Pete!
As mentioned I'm mainly interested in the center, you willing to separate them to keep shipping down? Can you post some good pictures of the center? Shipping to 87047.
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. Last edited by Sport/Truck; 06-30-2012 at 09:19 AM. Reason: Clarification |
06-30-2012, 09:24 AM | #5 |
Sierra Grande Club
What does one do for bolts? Are the bolts for the center the same as the ones used on driver / passenger side anchors?
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. |
06-30-2012, 09:31 AM | #6 |
Carpe manana
Hey! If I remember correctly the center shares bolts with the others....
06-30-2012, 09:56 AM | #7 |
Sierra Grande Club
That would make sense, but I read something that suggested they use separate bolts?
06-30-2012, 10:13 AM | #8 |
Carpe manana
When I replaced the non-OEM belts in my K10 I believe I just doubled up with whatever OEM bolts I scrounged from U-Pull It. Not sure if thats correct but here's a pic from my K20 that shows how GM did it....
06-30-2012, 06:22 PM | #9 |
if you cant work something out with sport/truck, i`ll take them.
07-01-2012, 12:02 AM | #10 |
more detailed photo of center belt. I will not be splitting these up. As mentione above, $40 shipped to lower 48 states
07-01-2012, 09:34 AM | #11 |
Sierra Grande Club
I'll take 'em can you send me your pay-pal info.
s/t
07-01-2012, 12:53 PM | #12 |
Carpe manana
If you don't want the outer buckles I'll take them and share the cost with you. I'm hoping to build a set of shoulder belts. Pete
07-01-2012, 08:40 PM | #13 |
Sierra Grande Club
You got! Can you PM me your info? I should see these by next weekend...
s/t
07-02-2012, 06:29 PM | #14 |
Sold and shipped to sport/truck
