Old 06-29-2012, 07:32 AM   #1
Daddy'O
Daddy'O's Avatar
Exhaust Manifold Bolts/Washers ?
Educate me please.
I have a pair of ram horn exhaust manifolds and have been told I need special washers for the exhaust manifold bolts. I purchased a new set of bolts from classic parts and they did not come with washers. Would someone confirm the need of these special washers & possibly provide a source for them?
Thanks!
Cheers - Wayne
Our Shop Build - http://67-72chevytrucks.com/vboard/s...d.php?t=620966
'55 Wagon Build - http://67-72chevytrucks.com/vboard/s...d.php?t=689157
1971 Cheyenne Super Ochre/White LWB 350 Auto - my son's truck "Nancy"
1972 GMC K2500 Custom 4X4 Olive LWB 400 SB 4-speed -"Greenie" - Restoration to begin after the '55
Nothing sucks more than that moment during an argument when you realize you're wrong.
Daddy'O is offline   Reply With Quote
Old 06-29-2012, 09:46 AM   #2
geezer#99
geezer#99's Avatar
Re: Exhaust Manifold Bolts/Washers ?
Most people just throw them away but here's some.
http://www.gmclassicparts.com/EXHAUS...C_p_26794.html
Old 06-29-2012, 10:10 AM   #3
Daddy'O
Daddy'O's Avatar
Great! Thanks for the link.
Now - are these washers as necessary as I've been told? And what are special about them as compared to a regular old run of the mill washer?
Thanks!
Cheers - Wayne
Old 06-29-2012, 12:39 PM   #4
Dano69c10
Dano69c10's Avatar
I have used run of the mill grade 8 bolts and washers on my ramhorns since the early 80's with no problems....
'69 Fleet
It ain't yours, if you didn't build it!
Dano69c10 is offline   Reply With Quote
Old 06-29-2012, 04:59 PM   #5
Wrenchbender Ret
I use grade 8 bolts & SAE grade 8 washers on all of them.
Wrenchbender Ret is offline   Reply With Quote
Old 06-29-2012, 05:40 PM   #6
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
^^^^ What WR said...
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 06-30-2012, 06:59 AM   #7
Daddy'O
Daddy'O's Avatar
So - absolutely nothing 'special' about the factory washers?
Cheers - Wayne
Old 06-30-2012, 09:47 AM   #8
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
They also use a locking tab thing that goes under two bolts and the tab folds up to lock them in. I don't have a good picture of it, but you can see them on this picture.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 06-30-2012, 10:31 AM   #9
Daddy'O
Daddy'O's Avatar
I just had an epiphany!
I think that’s what I was being told was ‘special’ – not the washer but the French lock.
Thanks s/t!
Cheers - Wayne
Old 06-30-2012, 04:33 PM   #10
Wrenchbender Ret
The factory washers were smaller in dia. & a little thicker but SAE washer are close & work good.
