06-29-2012, 11:35 AM | #1 |
292 flexplate info.
looking to change from 292 with 4 speed granny to 292 with th350 auto trans, what flexplate will i need to do the swap. i have a 1985 flex plate from a th 350
trans that was behind a 305 v 8 , but have heard it wont work.....can anyone help me on this..... |
06-29-2012, 12:40 PM | #2 |
member #16
Re: 292 flexplate info.
There is some 292 flex plate info in this thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=530691
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
06-29-2012, 01:16 PM | #3 |
john: thanks for the info.....still not clear what its going to take for the flexplate, i was hoping some one has done this that could chime in for the th 350 swap....
06-29-2012, 02:54 PM | #4 |
Count the teeth on your current flexplate that was used on your 292 and that should tell you which one to buy. 153 or 168. Can only be 1 of the 2. They cost $25 at truck shop in Orange,ca.
Stovebolt-It is painted |
06-29-2012, 03:08 PM | #5 | |
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
06-29-2012, 04:55 PM | #6 |
The 292 from about 67 up had larger mounting holes than the early models & the other engines. You can drill thev holes in the flexplate out to 1/2 in. & get bolts for the 292 flexplate.
06-29-2012, 05:15 PM | #7 |
It's Better With Nitro
When I helped my friend do his 194/PowerGlide to 292/700R4 conversion in his Chevy II, he went with a Pioneer L6 flexplate (pn: FRA112) that I had to machine the dowel holes and the dowels.
06-29-2012, 06:05 PM | #8 |
I have been going through this very thing lately and this is what I know: if you need a 168 tooth with a 10.5" torque converter pattern-they don't exist. I finally had to get a dual pattern flex plate and ream the crank holes to 1/2 inch (from 7/16") and add 2 more alignment pin holes. I did this today on my friends mill, because he has a turn-table with degree marks so it was super easy to get it right. I am happy to report that my newly modified flex plate is mounted and if I knew how much to torque the bolts, I'd put in my trans.
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
06-29-2012, 08:07 PM | #9 |
thanks to all.....this was the kind of info i was needing...not sure how many teeth my flywheel has but i will try and find out before i start the tear down. the flex plate i have i can count the teeth on it.... and see what size the torque converter is....would rather have the info. before i start...instead of diggin up a bunch of snakes half way into the project....thanks again and if anyone else has an idea please let me know.....
06-29-2012, 11:44 PM | #10 |
How are your starter arraigned? Mine are straight across from each other, instead of on a diagonal like most all others. I never could find the right starter nose in the junkyards, so I had to buy one from a starter shop ($20 or so) and the starter company had to order it and it took a week to get it, so I had them go ahead and build me a starter. This bolts-straight-across nose seems to be the reason you have to use a 168 flex plate (168's are 14" across, and the 153's are more like 13" or a little less).
This picture, you can see how my starter is bolted on. I'm not a very good picture editor, but the heavy black line is about how the outer bolt is, and the little arrow is the inner bolt. I can take a better picture if you need.
06-30-2012, 10:38 AM | #11 |
pritch: the pics are great.....the more info i can get the easier it will be on me, i have not checked my starter bolt up yet but i need to check that out also...
thanks for the info.....this is my first inline six project, i like the 292 but its alot different that the v-8 stuff.....love the pics... |
