Old 06-29-2012, 02:10 PM   #1
rchavez101
rchavez101's Avatar
Motor/engine mount question
I am gathering my parts for my engine swap on my 94 with a 4.3 liter to a 5.7 liter. Can someone give me a link to the engine/frame mounts that I would need? I have looked but all I can come up with are the rubber mounts. I am assuming that one of the mounts is the steel/rubber part and the other is steel (cradle). Thanks in advance for your help.
94 Chevy SWB in progress.
http://67-72chevytrucks.com/vboard/s...d.php?t=477390
rchavez101 is offline   Reply With Quote
Old 06-29-2012, 04:00 PM   #2
jchav62
1962 C-10
jchav62's Avatar
Re: Motor/engine mount question
I think the ones are your 4.3 will bolt onto the 350. I'm not 100% sure, but I would try if I were you.
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 06-30-2012, 12:14 PM   #3
rchavez101
rchavez101's Avatar
Thanks Joe. Its good to see someone local and on top of that a Chavez as well.
I went to Autozone and asked to see the motor mounts for the 4.3 and 5.7 liter engines. Sure enough they are different. It shows that the rubber mount goes on the frame for the 5.7 liter. The only part that I am unsure of is the part that is attached to the engine I believe some call it the cradle. I am hoping that the one that is on the 5.7 currently will fit over the new mounts. The 5.7 liter is a Gen 1 block.
Old 06-30-2012, 01:59 PM   #4
Mr_Rich
Mr_Rich's Avatar
I would call it a bracket vs. a mount so as not to get the two confused. Obviously, these are the mounts...
1989 K1500 Chev. EC
Original owner; some of the aftermarket parts I've installed are Borla headers, Hypertech chip, Edelbrock water pump, and a Stillen rear disc brake conversion kit.
2009 Hummer H3T 3.7L 5M (sold)
1997 K2500 Chev. EC 7.4L/ 4L80E (sold)
2018 Dodge Ram 2500 HD R/C
Mr_Rich is offline   Reply With Quote
Old 06-30-2012, 02:56 PM   #5
rchavez101
rchavez101's Avatar
Thanks Mr. Rich. Now i need to see if the part on the engine will fit around the mounts.
Old 06-30-2012, 05:37 PM   #6
Mr_Rich
Mr_Rich's Avatar
You need brackets like this. On each side of the engine brackets are braces/ brackets that tie in to the bellhousing on a 4WD. A trans for a 4WD has additional bracing that a 2WD doesn't use. A 2WD may need a spacer in place of the brackets on each side that I've shown.
1989 K1500 Chev. EC
