Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 06-29-2012, 06:20 PM   #1
1774btcrew
1774btcrew's Avatar
FS completely gone through manual/floor shift tilt steering column with key
This is a manual floor shift tilt steering column with key for the 78-83 trucks. It will work for 1978 and earlier with the correct intermediate shaft(I have this as well for an additional $20). When I purchased this steering column the lower collar that meets the dash bezel was cracked and missing pieces. To repair this I had to COMPLETELY disassemble this column. I replaced the broken collar, cleaned and regreased everything, and put loctite on the tilt mechanism bolts before carefully putting everything back together. This now works as new with no play. If you are familiar with these at all it is VERY time consuming and involved to take these completely apart and reassemble them correctly. For this reason I want $200 FIRM for this NOT including shipping.
1774btcrew is offline   Reply With Quote
