Old 06-29-2012, 09:25 PM   #1
ooimpalaoo
ooimpalaoo's Avatar
c-notch help fast please doing it right now..
ok so im installing the c-notch right now in my 69 C10 the install instructions are in bad shap right out of the box but it looks like they want me to take the rivets out of the track bar mount on the frame ???? is that right can i not run my stock bar with a notch??? and if not im guessing that i dont mount it in the same spot it came from thanx for the help..again and again
ooimpalaoo is offline   Reply With Quote
Old 06-29-2012, 09:29 PM   #2
ooimpalaoo
ooimpalaoo's Avatar
Re: c-notch help fast please doing it right now..
ok after another look it looks like they want me to bolt the notch in the holes that will be left after i grind the rivets out on the track bar ...sorry the instructions that cpp sent me are torn and dirty...
Old 06-29-2012, 11:09 PM   #3
Fattback
Fattback's Avatar
This the same as what u have?
http://www.classicperform.com/Instru...DF/6372CNK.pdf
Rob
Fattback is offline   Reply With Quote
Old 06-30-2012, 12:10 AM   #4
ooimpalaoo
ooimpalaoo's Avatar
yes thats it thanx man just wanted to get it in and didnt even think to look on the cpp site...the rivets are crazy to get out ground both sides of the rivet off and couldnt knock the slug out...had to drill a hole in it then knock it out not fun...
Old 06-30-2012, 09:58 AM   #5
Fattback
Fattback's Avatar
Im getting ready today to take on those rivets today myself. Relocating the rear top shock brackets.
Old 06-30-2012, 11:52 AM   #6
ooimpalaoo
ooimpalaoo's Avatar
well if you cut a X into the top of the rivet you can knock the heads off fast with a chisel and hammer....far faster then grinding them off with a flap disk on a grinder..
Old 06-30-2012, 11:25 PM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
Even with a Blue Point air chisel they can be tough mo-fos to get out. Some fall right out and others take a LOT of effort.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 07-01-2012, 12:41 AM   #8
ooimpalaoo
ooimpalaoo's Avatar
out of 8...only one was (easy) and it wasnt very easy at all...would love to see this done in 4 hours lol lol im on day 2 and still not done
Old 07-01-2012, 09:54 AM   #9
gringoloco
A guy with a truck
gringoloco's Avatar
Just wait til you find a reason to remove the trailing arm crossmember...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 07-01-2012, 10:30 AM   #10
dznucks
dznucks's Avatar
x2 get you a plasma cutter for that job
dznucks is offline   Reply With Quote
Old 07-01-2012, 10:35 AM   #11
ooimpalaoo
ooimpalaoo's Avatar
lol i was looking over at it when i was doing the notch....i think i would start with a new frame...cab off....the frame under my truck is not in the best shape
