05-17-2003, 09:34 PM | #1 |
Insterment Panal Swap?
Help...Need Help...
I recently swaped out my basic insterment panal in my '70 with a full gages panal from a '72. So far I am only able to get the turn signals and Volt meter to work. When I pull the wire plug and check for ground and juice, it seems that they are ALL or Most of them are grounded. Can anyone tell me if they have done a similar swap and if so, what did you do to make it all work? Thank again to all. |
05-17-2003, 09:37 PM | #2 |
PROJECT 7DEUCE
The wiring harness for a full gauge set and basic set is different...You can do a post search for the topic and get you anwser....
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
05-17-2003, 09:48 PM | #3 |
Which gauges are your using in the new setup...?
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
05-17-2003, 09:52 PM | #4 |
Seņor Member
Here's a schematic and instructions for how to make them work.
http://www.gmcpauls.com/Tech%20Tips1.htm
05-18-2003, 12:56 AM | #5 |
its all about the +6 inches
You probably fried your fuel guage. I did this once before I found out the internet was a good place for auto info.
Back in the 'dark ages' I guess. |
