Old 06-30-2012, 01:01 AM   #1
1978chevybigten
1978chevybigten's Avatar
Having some speedometer issues
ok guys on my 78 the PO took out the speedo cables and filled up the hole on the trans with silicon, i finally got all of it out and now i cant figure out how to connect the lower speedo cord does is just screw into the trans or is there something missing? all there is on the trans is threads. does something else hook up to that? or just the lower cable? if yal could put up a picture example it would really help out. also its a 350 turbo trans if that helps and if anyone has a working speedometer for the 78 please pm me!
1978chevybigten is offline   Reply With Quote
Old 06-30-2012, 02:23 AM   #2
1978chevybigten
Exclamation Re: Having some speedometer issues
heres the picture if that helps at all! id like to get this figured out before this weekend
Old 06-30-2012, 11:26 AM   #3
75chev4x4
75chev4x4's Avatar
Its a 2wd truck right? What does the hole look like, can you see into the trans or is there a spot fro the cable to go into?
75chev4x4 is offline   Reply With Quote
Old 06-30-2012, 11:51 AM   #4
1978chevybigten
i finally pulled all of the silicon out of the hole, and tranny fluid started pouring out, im assuming that theres supposed to be a gear drive where the silicon was? what would be my best bet on fixing this?
edit: yes it is a 2wd
1978 big ten 350/350:chevy
Old 06-30-2012, 11:56 AM   #5
75chev4x4
75chev4x4's Avatar
If its just an open hole I would go to the junk yard and get the part that threads into the trans and that the cable threads onto. You will need to look inside and see what Colorado driven gear is on the trans and that will help you decide what drive gear you will need to buy that will fit in the insert your getting at the junk yard. You will see when you take the part off the donor truck how it fits in.
Old 06-30-2012, 11:57 AM   #6
75chev4x4
75chev4x4's Avatar
http://www.tciauto.com/tc/speedometer-gear-calculator
This site should help you
Old 06-30-2012, 12:02 PM   #7
1978chevybigten
thanks man, im thinking about getting both new gears? i mean there had to be a reason he took the gear drive out! do i just need to buy the right tooth count? also my trannsmission isnt stock apparently its from a "camaro" thats what the po told me so could you help me in finding the vin numbers?
Old 06-30-2012, 12:06 PM   #8
75chev4x4
75chev4x4's Avatar
Look Athens the driven gear and if its in good shape run it or you can change both if u want. The vin numbers on the truck or numbers in your tranny? If the po had problems like I do with the speedo on mine I can see why he plugged the hole haha.
Old 06-30-2012, 12:08 PM   #9
1978chevybigten
On the trans.
Old 06-30-2012, 12:10 PM   #10
75chev4x4
75chev4x4's Avatar
I think they are on the tailshaft somewhere.
Old 06-30-2012, 12:11 PM   #11
1978chevybigten
Ok thanks man!
Old 06-30-2012, 04:49 PM   #12
1978chevybigten
Also I was originally set up for cruise control, but I'm not going to hook it up, could I run a speedo cable from the trans strait to the speedometer?
Old 06-30-2012, 05:23 PM   #13
75chev4x4
75chev4x4's Avatar
You shoukd be able to if you get the longer cable just go from the speedo to the trans, I don't see why you couldn't?
Old 06-30-2012, 05:48 PM   #14
1978chevybigten
That's what I was thinking just wondering if someone has done it before.
Old 06-30-2012, 09:30 PM   #15
Pop's C-10
Pop's C-10's Avatar
They sell tha cable that goes from speedo to trans..for non cruise ope'd model...i'm seen them in LMC...I'm sure you can get one fron a parts house.
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 07-03-2012, 12:17 AM   #16
1978chevybigten
heres another question, i found a nice speedo in good shape but its from an 85, would it still work on my 78?
Old 07-03-2012, 12:28 AM   #17
chebyshortbox65
chebyshortbox65's Avatar
Yes the 85 speedo is a direct bolt in but it has a little diffrent face and only goes to 85 also that is a truck trans camaro only came with a short tail shaft 350
chebyshortbox65 is offline   Reply With Quote
