Old 06-30-2012, 09:57 AM   #1
Readyforduty24
over heating issues
i have a 90 3/4 ton 4x4 with a 350 standard tranny in it. thing is over heating but i'm not losing coolant any where............. i'm confused as to how this is happening. the only thing i can think of that would be causing my gauge to read as over heating is the coolant temp sensor. has anyone else had this issue? if so where should i start my search for the issue?
Readyforduty24 is offline   Reply With Quote
Old 06-30-2012, 11:30 AM   #2
Eyegore
What Hump?
Eyegore's Avatar
Re: over heating issues
This happened to me, it turned out my radiator was restricted, higher rpm should cooled it but made it overheat. Check radiator adn thermostat.
Lil red 86 c-10
99 Sub
78 Camper Special w/ 454
Eyegore is offline   Reply With Quote
Old 06-30-2012, 01:42 PM   #3
Readyforduty24
ok thanks man, i live in the panhandle of nebraska and its been hotter then normal around here. over 110 some days yesterday was the hottest day and thats when it started to do this.
Old 06-30-2012, 01:48 PM   #4
Mr_Rich
Mr_Rich's Avatar
Take a hose and rinse your radiator through from the backside. You'll be amazed at all the garbage that collects in the cooling fins. I rinsed my rad. and when I finally removed it for my engine install I still washed a LOT of crud from the cooling fins. This should be a summertime maintenance routine.
1989 K1500 Chev. EC
Original owner; some of the aftermarket parts I've installed are Borla headers, Hypertech chip, Edelbrock water pump, and a Stillen rear disc brake conversion kit.
2009 Hummer H3T 3.7L 5M (sold)
1997 K2500 Chev. EC 7.4L/ 4L80E (sold)
2018 Dodge Ram 2500 HD R/C
Mr_Rich is offline   Reply With Quote
Old 06-30-2012, 11:25 PM   #5
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
In the same way that crud builds up on the radiator, it will have built up on the AC condensor. Even if the AC doesn't work, that will also block the movement of air thru the condensor and the radiator.
Member Nr. 2770
Old 07-01-2012, 12:10 AM   #6
Boog
laying low
Boog's Avatar
The fan clutch may be getting weak. Also is the fan shroud in place?
Boog
Old 07-01-2012, 10:33 AM   #7
Readyforduty24
yea the fan shroud is in place, clutch felt like it always has it moves but does not spin freely, i did rinse out the rad but did not do it from the back side so i'll try that today. i replaced the thermostat it still over heats just not as fast now hahaha. thanks for all the help! gives me a few places to start looking.
Old 07-01-2012, 10:56 AM   #8
Kim57
Kim57's Avatar
When mine started over heating I changed the thermostat and the radiator cap.
That cured my problem. Seems the cap wouldn't hold pressure any longer.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 07-01-2012, 06:15 PM   #9
Readyforduty24
i changed the thermostat, and the cap as they are the cheapest to replace and its still over heating. the only time i can get it to cool off is if i pop the hood and run the heater full blast then it'll cool off to normal temp. if i don't do these it'll over heat to the point of the gauge pegging out. it doesn't boil over either. i've sprayed out the radiator and condenser several times today. still no change.
Old 07-01-2012, 09:18 PM   #10
gregory5000
Does it appear to be overheating in the engine compartment? It sounds like you may have a gauge issue. If the gauge is going to the max that is like 260 degrees. I may be off base not having all the info, just an observation. Hope it is just a gauge issue.
2001 GMC 2WD, 1998 Chevy K2500
gregory5000 is offline   Reply With Quote
Old 07-01-2012, 11:19 PM   #11
Readyforduty24
yea thats what i'm hoping, tomm. when i get to work i'm goin to test the ohms on the sensor and see what it reads...... hopefully its just that.......... ugh.
Old 07-02-2012, 11:23 PM   #12
Readyforduty24
so i used a thermotemp gun on it to get a reading on the water temp. when the gauge was saying the engine was over heating. well either the sensor is bad or the gauge is bad, because the temp of the coolant at the thermostat housing was 191 degrees and at the lower hose it was 141. so now i know its not the engine lol.
Old 07-05-2012, 10:05 PM   #13
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Now that you know the temps, I gotta ask...have you done a pressure test on the system? Even if it isn't leaking, at least you'd know if there was a weakness.
But, at least you know more than your guage is telling you. I just use my guage for a reference point. My radiator started leaking and I replaced it a couple of weeks ago. Pressure test showed me where the weakness was.
Member Nr. 2770
Old 07-05-2012, 10:11 PM   #14
Readyforduty24
no i haven't done a pressure test as of yet........... i'm thinkin i should though.
