Old 06-30-2012, 06:50 PM   #1
Stephanie
Stephanie's Avatar
Flywheel problems
So, B_Hix (Brad) was an amazing friend and stopped by today with his cherry picker to help us get our engines out of Chester He stayed and assisted us for a few hours, but we learned quickly that our engine is going to be very very VERY difficult.
I need your help! Would someone please tell me how to remove these bolts from the flywheel??
We are at a loss! We have tried for over two hours to try and get them off. We have tried letting them sit in lubricant and nothing will budge. Even tried banging the wrench with a mallet to try and jar them loose, but nothing! It is the very last thing standing between us and being able to reach the bolts to get the bellhousing free so we can FINALLY attach our engine to the engine stand. I am hoping and praying that someone on the forum has the answer or can point me in the right direction.
Thank you all in advance!
Boys aren't the only ones that like to get their hands dirty! \m/(@o@)\m/
1950 Army Chevy 3100 build: The Chester Chronicles
Proud Army Wife!
Stephanie is offline   Reply With Quote
Old 06-30-2012, 07:11 PM   #2
Red Foreman
Red Foreman's Avatar
Re: Flywheel problems
Hi Stephanie, assuming you haven't tried this already but the easiest way is to use an air impact rattle gun "well thats what we call them here in Australia" only use a impact hex socket to prevent anymore damage to the bolts. Hope this helps, George.
RIP John (Lambis), my beloved Father & best Friend.
My Build 56 GMC
http://67-72chevytrucks.com/vboard/s...d.php?t=486721
Red Foreman is offline   Reply With Quote
Old 06-30-2012, 07:18 PM   #3
mr48chev
mr48chev's Avatar
An impact would be nice but a long handled handled 1/2 inch flex bar and a six point socket should work. You might need a cheater pipe to break them loose. Remember they unscrew counter clockwise.
If the flywheel turns when you try to take them loose and it should put a stick of wood between the flywheel teeth and the right side of the bellhousing to hold it from turning.
I've also screwed a long bolt into one of the pressure plate bolt holes so it would catch on the edge of the bellhousing and hold it.
Old 06-30-2012, 09:27 PM   #4
B_Hix
B_Hix's Avatar
Hi Stephanie - any luck? Can bring over a breaker bar, etc if need be...
^^ Was great meeting Stephanie and her husband - they've got a really cool project going!
'49 Chevy 3100; 350/350; 305 H.O. P/P heads; 10.5:1; 370 hp; '75 Firebird clip, rearend & steering column; 7+ year home build
B_Hix is offline   Reply With Quote
Old 07-01-2012, 03:58 AM   #5
55dude
55dude's Avatar
impact, air or electric would remove them.
55dude is offline   Reply With Quote
Old 07-01-2012, 09:04 AM   #6
ET56
ET56's Avatar
In the Picture the locking tabs haven't been pushed down. You did do that right? Just checking sometimes the little things can be overlooked. Great project you have going. Best of luck.
56 Chevy Pickup, 66 Corvette
ET56 is offline   Reply With Quote
Old 07-01-2012, 10:16 AM   #7
Wrenchbender Ret
It helps to grind the surface of the 6 point socket down a little. They are tappered on the end so you will get a better grip if it is flat.
Wrenchbender Ret is offline   Reply With Quote
Old 07-01-2012, 11:52 AM   #8
Rude Dude
Rude Dude's Avatar
Heat it with torch or propane until they are red, spray penetrating oil then remove with impact wrench.
Rude Dude is offline   Reply With Quote
Old 07-01-2012, 01:03 PM   #9
mr48chev
mr48chev's Avatar
I've never had to do that on a flywheel bolt. I'm thinking they just don't have enough handle on the ratchet they are using to break loose 80lbs and maybe more torque on the bolts.
That or the engine is turning when they are trying to break the bolts loose.
Old 07-01-2012, 04:20 PM   #10
Gator Alum
What he said. I keep a 4 ft metal pole for this reason. Slide it over the handle to the 1/2" drive breaker bar (I've used wratchets before and you can end up snapping their gears, but yay Craftsman warranty). When you hear the snap you'll think the breaker bar broke, but it's just the bolt popping loose.
Gator Alum is offline   Reply With Quote
Old 07-01-2012, 05:01 PM   #11
mr48chev
mr48chev's Avatar
I lucked out years ago when my father in law gave me a 3/4 drive breaker bar that is about 28 inches long. I have a 4 ft cheater pipe that slides over the end of it though.
Old 07-01-2012, 11:59 PM   #12
Stephanie
Stephanie's Avatar
You all are so wonderful! The tips and advice was absolutely perfect! B_Hix let us borrow his breaker bar and we were able to pop the bolts free after jamming a screwdriver against the flywheel and the oil pan to stop the engine from turning as we bared down on those bolts. Great jerry-rigging there :P After a few wakes with a mallet, it popped right off onto my finger :P Haha! Walked away with only a bit of a swell which was nice, but that flywheel just had to have one last go at us.
Thank you all again for all the tips and advice I love this forum because of all these response right here
Proud Army Wife!
