06-30-2012, 08:12 PM | #1 |
2WD Jimmy
Quick Ratio pwr str box from ECE..
Anyone using one? I have one I bought a few years ago, it looks no different on the outside and bolted right up. My problem is, I can't seem to get anything to fit the high pressure OR the low pressure side of the box. The fitting that I have For the high pressure side says it is for 79 and earlier Saginaw boxes, but it seems a wee bit too big. I think the low pressure side is supposed to be 3/8" but that seems to be too small.
Any ideas??? Posted via Mobile Device Last edited by Tom Vogel; 07-01-2012 at 09:32 AM. Reason: spell |
06-30-2012, 09:00 PM | #2 |
Re: Quick Ratio pwr str box from ECE..
18mm and 16mm x1.5 o ring. the later boxes usually use these. Please confirn this someone if you can but the 80's car boxes are these fittings so I'm guessing yours is too
