Home Built '87
How to fix the spring in the column for the gear lever
Hi;
I've been searching without luck to find a thread on how to fix the spring in the column that holds the gear selector lever taught. I can see that my spring is broken, but I am unsure how I would go about replacing it....would I have to take the entire column apart to access it? Any suggestions?? Thanks!
Gordon 1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424 1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833 Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969 |
Re: How to fix the spring in the column for the gear lever
I did it not too long ago, IIRC I just picked it out with a pair of needle nose. It came out in two pieces. I picked the longer of the two, streched it as far as I could and squeezed it back in.
It isn't great but it's not nearly as floppy. I found a source that actually sells just that little spring - let me look around. Found it (well one place anyway) - 18 bucks, that's probably why mine is still loose. Just the spring: http://www.steeringcolumnservices.co...ng-2310995.php and every other column part you could imagine: http://www.steeringcolumnservices.co...le-pontiac.php Oh yeah, as a bonus - if you buy a part you also get free access to their repair tutorials. Last edited by chengny; 07-01-2012 at 07:38 AM. |
The bone yard is full of them. A column ins't that complicated. A few special tools needed for a tilt but they are available fairly cheap at most parts houses or Harbour Freight. The other option is to get a complete column out of the bone yard and install it instead.
#4 | |
Home Built '87
So, is there a better way to get the spring out than stretching it? I have most of the tools for steering wheels / columns. Thanks!
Home Built '87
http://en.allexperts.com/q/Steering-...r-selector.htm
http://www.chevytalk.org/fusionbb/sh...hp?tid/271793/ http://www.carcraft.com/howto/56459/index.html http://www.gm***************/forum/s...?t=3085&page=3 Found some info on other sites, should be good to fix it now. Thanks guys!!
