Old 05-18-2003, 12:43 AM   #1
krazy_texan
krazy_texan's Avatar
driveshaft quistion
a guy at work offered to trade me transmissions because i want the 3 speed manual, and he wants the th350, problem is that he has a 68 shortbed and i have a 71 longbed, would we have to get new driveshafts or would we be able to use the ones that we have in the trucks or is the one for the automatic in my longbed than the one for the standard. Also what would this do for my gas mileage.
Krazy Texan
My Trucks are made with Wrenches not Chop Sticks
1967 GMC 3/4 ton "Johnny Cash"
1990 v1500 suburban
1967 Ford f100 Swb 4x4 "green bean"
GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO
krazy_texan is offline   Reply With Quote
Old 05-18-2003, 05:14 PM   #2
crazy longhorn
Fabricate till you "puke"
if the 68 has a saginaw 3 spd(id by a 7 bolt side cover), it will be a direct swap with a short 350 turbo(6 " tail housing). The spline will be the same, no driveline mods. One of you will have to swap crossmembers tho......the 3 spd stick will bolt to the auto crossmember, but the stick has a bell mount crossmember & will need to be changed to mount the auto trans. If the guy has the Muncie 3 spd(4 bolt side cover).......you dont want it! they are a weak trans. good luck, crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
