I have 2000 chevy Silverado 1500 4x4 with the 5.3 and it is overheating. When it first started I replaced the thermostat, then the water pump, then the radiator, and the clutch fan and it continues to over heat. With it still overheating I thought that I might have had a bad thermostat, or water pump so I changed them again as well as the sending unit, but alas it still is running hot
. I also have tested for a blown head gasket and it is fine. Any help please before I use some DuPont wrenches on it.
![]() ![]() Chris67 c10 swb build in progress 70 c10 lwb driver pending parts for drastic overhaul 70 c20 lwb parts truck for above mentioned drastic overhaul 71 k20 lwb building for off road use and towing |
| Bookmarks |
