![]() Join Date: Jan 2001
Guess What I Found In The Junk Yard??
Found a '71 with the all-too-rare shoulder belts. The bad thing is they are both broken and really frayed. This whole truck was a rolling POS nothing and I mean NOTHING was salvagable!!! Too bad too
boots
You need to snag the upper boots. What color? The rest can be remade with existing parts.
1967 K30 Napco 292/SM420 original paint 30k miles 1968 K60 Napco 396/5spd. dbl frame 52" michelins 1969 K10 SWB GMC 454/4spd 6" 35's posi,hooks 1972 C30 longhorn,BB/AT,A/C,Tilt,Toolbox,lokr 1987 K20 Chevrolet Suburban. 6" lift. 5.7L/TH400 1979 K60 GMC Coleman 4x4, 427/Allison. |
Seams to me if the holders are in good shape, you get the mechanism and replace the webbing?
Does anyone know if that's possible? There may be a good find after all ![]() |
its all about the +6 inches
There isn't much of a mechanism to them. They don't retract or anything. Just a strap and buckle.
Go back and grab whatever is left of the shoulder belts...been trying to divise a way to make them...I'm sure I'd want the pieces, as others...now that I started this next elusive parts search.
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
Old member
Those are the 2 main ingredents for shoulder harnesses set up. I would grab them and any good upholster shop should be able to redo them as far as the straps.
I wouldn't let them go. ![]() ![]() ![]() ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Running on empty
_____________________________________________ Tim We have two rules here at the Rock. Rule #1: No writing on the walls. Rule#2: Obey all rules 70 GMC Sierra Grande "Custom Camper" Longhorn 402 Big Block TH400 PS PB factory AC Posi; 94 Bronco XLT 302, auto;worn out daily driver ![]() |
#8 | |
