07-01-2012, 03:14 PM | #1 |
Registered Cruiser
77 sb with DM/LS swap... tunnel cab???
Anyone out there running an LS/700r4 with PB's Dropmember, and had to tunnel the cab? Nate said the trans angle should be around -5 degrees. Well I can get it to about -7*/-8* before it hits the cab floor.
My truck was originally set up with a 2-piece drive shaft, but I'm switching to a one piece. Looks like I will definitely need to cut the carrier bearing crossmember to clear, but also looks like the drive shaft will hit the cab floor. Is this something anyone else has ran into??? Thanks, Justin
77' Chevy SB Dropmembered Front and Rear 5.3/4l60e combo |
07-01-2012, 09:27 PM | #2 |
Registered Cruiser
Re: 77 sb with DM/LS swap... tunnel cab???
I know we all love pics.... maybe these will get the ball rollin....[ATTACH][ATTACH][/ATTACH][/ATTACH]
07-01-2012, 09:53 PM | #3 |
Looks great but sorry I don't have an answer for you.
Rob |
07-01-2012, 10:05 PM | #4 |
Registered Cruiser
Thanks Rob lol
07-02-2012, 11:39 AM | #5 |
Registered Cruiser
Nobody here with a DM/LS swap that can chime in?? If I have to tunnel it that's fine, just want to know if there is an alternative guys are using...
07-02-2012, 08:20 PM | #6 |
It'd be alot cooler if you did
Looks sweet... no idea.
Posted via Mobile Device |
07-02-2012, 11:43 PM | #7 |
Registered Cruiser
It's cool, verified with PB, that I do need to tunnel, slightly, for the one piece drive shaft. Didn't realize it but the LS sits about 1-2" higher than an sbc. For anyone else that needs to know.
Thanks for the compliments fellas!
